I have a honeywell magicstat thermostat for my heating/air - it will not get off the sleep mode?
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
4-wire typical wiring of a thermostat is: Y (Yellow) G (Green) W (white) and R (red). Inspect the thermostat to see if it has a jumper from R1 to R2. If not, put your red wire on R2. On a 5-wire thermostat you may have a blue wire. This will go to the common terminal (usually C but sometimes B) check the inline fuse in the air handler to see if it has blown. Replace it only after wiring the thermostat correctly.
Posted on Dec 03, 2007
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
  • 182 Answers
SOURCE: Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Posted on Nov 20, 2008
roadrunning1
  • 152 Answers
SOURCE: Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
Posted on May 11, 2009
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
I am unable to set the wake and sleep setting and have to use the hold mode to control heat.
Go in to the cooling/mode program check the temp/time setting must not conflict with the desired heat setting.
Mar 21, 2010 | Honeywell Electronic Programmable...
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
What wires go to what
The colors you have are not standard.
Your going to have to see where the wires connect on your appliance to answer this. find out and post back
Nov 29, 2008 | Honeywell Electronic Programmable...
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
No heat in zone with Honeywell rth230B
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Nov 01, 2008 | Honeywell Electronic Programmable...
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
