Question about Meade DS-2114 ATS (325 x 114mm) Telescope
It won't rotate the part that the gear attaches to is broke I need a new one
  • 3,186 Answers
Meade has the part. The question is will they sell you just the part? Usually they want you to return the entire scope for repairs.
Call them here and discuss:
http://www.meade.com/support/index.html
Posted on Sep 09, 2010
The mixer won't work the pasta attachment, keeps rotating the mixer motor.
It sounds like it could be a possible stripped gear. You could have a bad attachment drive gear or bevel pinon gear.
Best thing to do would be to take the mixer apart, and inspect those gears. Here is a link to the service manual which will aid you in taking apart your 4.5 quart mixer: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Here is a link to the attachment drive gear: http://www.mendingshed.com/attachmentgear.html
Here is a link to the bevel pinion center gear: http://www.mendingshed.com/pinionwormgear.html
Let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid K45SS Classic Stand Mixer
1991 Honda Civic DX Why am I able to push the car with automatic transmission while it's in park? The car won't start and run, either.
If the car rolls with the shifter in the park position and the starter will not engage the engine than the transmission is not in park. This could be caused by a bad shift cable. In order to confirm this you will need to find the area where the shift cable attaches to the transmission. While a helper runs the shifter through the gears check the linkage at the transmission to see if it is moving. If the linkage is not moving that there is a problem with the shift cable or the shifter. Some disassembly of the center council may be necessary to gain access to the area where the shift cable attaches to the shifter to see if it is still attached to the shifter. If it is and the shifter is moving the cable than the cable will need to be replaced. If the cable is moving the linkage at the trans than there is probably something wrong internally inside of the transmission. If you have any questions or need further help I will be happy to do what I can!
Sep 06, 2011 | 1991 Honda Civic
Having problem with Kenmore ice maker (wr30x0289). Won't fill. Looking for wiring diagram for Kenmore 363.9738580 Refrigerator.
The wiring diagram your seeking is NOT published on line,i can give you a list of potential problem causing ice not to be made
1) gear on i/m is broke,remove cover on i/m and check if main drive gear is cracked
2) the water inlet valve,rotate fingers on im till it starts turning, access water valve on rear of refrig.
let i/m make a complete 360 degree cycle at one point (toward the end) thier will be 120 volts to
valve,if 120vac to valve and water pressure good at vavle,replace defective valve(unplug valve
and place meter leads into plug/one lead on each wire)
3) a internal switch on i/m, if it makes 360 degree cycle and 120 not to valve,one of switches is bad,
the parts down break down doesn't tell which is for water valve and w/o diagram i dont know the
color wires on switch that sends 120vac to i/m so replace all 3
4) the internal i/m cam that attaches to above mentioned gear is ground down and not closing the
correct switch whe it is supposed to be closed,remove gear and metal plate on i/m if cam is
grooved and gouged up,replace cam
part#s
gear WR29X5162
water valve WR57X10033
switch(s) WR29X5171
cam WR29X5167
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Refrigerators
I have a 2002 zxj 600...the gear shift knockle broke so I got another on,so I replaced it with a new one,and the problem is I cant get it too shilt right I dont know how too put it right...can you help me...
The knuckle needs to be in the correct position on the splines. Mark it, so you will know where it is now, remove and rotate one spline, then test. If you still have trouble, rotate it the opposite way. You should also have some linkage adjustment to position the selector properly--The gears should engage, it's possible the shift forks are the problem. Hope this helps.
Jul 13, 2011 | 2003 kawasaki ZX-6R
MY ryobi bc30 expandit starts,but the weedeater head is not rotating
The drive may be broke. It travels from the head to the engine. The drive spindle is attached in a hole at the engine and the engine rotates the spindle to rotate the head. The drive spindle must be broke inside the shaft, the engine or the head. If this is the case, a new weedeater will be a better option.
Jun 04, 2010 | Top Expressions " INDUSTRIAL SPRAY PAINTER...
Somthing broke
Hm, definitely something broke inside the tranny or drive gear as the gear belt still to tight when you rode it out. Better cheeck your tranny parts.....
Apr 16, 2010 | 2001 Victory V 92 C Deluxe
ECG PAPER DOES NOT ADVANCE
Hello fbadin1, contact Marquette/GE with model # of unit and order the paper drive assembly. Been there do that. Merry Christmas.
Nov 22, 2008 | Ge Medical Systems Medical
Throttle assembly
WELL IT TURNS OUT YOU NEED TO ROTATE THE SPRING TWO ROTATIONS AND CLIP IT TO THE THROTTLE PLATE THAT ATTACHES TO THE THROTTLE CABLE
Nov 18, 2008 | 1988 Honda Civic 2 Door
1988 toyota camry 2.0 engine (timing)
Pull #1 spark plug and rotate the engine until you hear air rush out of the cylinder, (plug the hole with your finger if you can), then look at the timing mark, it will be close to TDC
Oct 04, 2008 | 1988 Toyota Camry
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
54 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
