Question about Homelite Mighty Lite Lawn Trimmer
My home lite start when on half choke but shuts off in a few seconds to a min. or if i put it on run it immediately stalls
    Problem Solver:
  • 6 Answers
Check oil fuel mix, i had same problem and mix was incorrect
Posted on May 17, 2012
  • 183 Answers
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Posted on Sep 09, 2010
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
How to start
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
Nov 08, 2013 | Poulan WeedEater Hedge Trimmer 25cc Engine
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
My homelite will no longer stay running.
i would start at the muffler & pull it off ,,ck out the exhaust port where u just took the muffler off,,see if it is loaded up with carbon,,need to clean it out,,i find then in the trash,,& take them apart,,and most of the time its just that,,because u are using a gas & oil mix,,try it ,, hoped it helped,,
Apr 15, 2010 | Homelite Consumer Products MightyLite...
Stalls out at full throttle
Has the air filter been removed, damaged, or the airbox not seated propelry on the carbs neck, this would cause it to run lean hence requiring the choke to be in operation all the time. Have you tried fresh fuel?? This goes stale after a while. I hope this is helpful, Ian
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
I hit a puddle and now my truck won't run
Use a heat gun to dry off all ignition components. If that doesn't do it, start looking into a partially "Hydro Locked" Engine.
Dec 28, 2008 | 2004 Ford F150
Homelite Mighty Lite Lawn Trimmer  Logo
376 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
