I received one url.. that does'nt working.. - Computers & Internet
  • 835 Answers
What was the link?
Posted on Sep 09, 2010
How do I get (Sabrent NT-WGHU) this wireless usb adapter to work on windows 8.!?
As far as I can tell it should use universal wifi drivers that are built into Windows 7 and above. That said I suspect you may need specific drivers for Windows 7, 8.1, and 10 to make it work correctly. You'll also have to choose it as your main wifi connection once installed over any internal wifi your computer may have. You can find the drivers by searching NT-WGHU at the linked url below. Make sure you click the "windows" banner to get the appropriate driver. http://www.sabrent.com/downloads.php
Jan 12, 2015 | Sabrent NTWGHU HighPower 1000mw Wireless...
The ntvdm cpu has endountered an illegal instruction. Cs:0df1 IPL01f6 OP: ff ff 00 00 ff
SYMPTOMS
When you attempt to run a 16-bit program on a computer running Microsoft Windows NT 4.0 Service Pack 3, the program may quit immediately, or you may receive the following error message:
Hidden Console of WOW VDM
The NTVDM CPU has encountered an illegal instruction.
CS: 04c3 IP:3937 OP:c71c 9d 37 00
Choose Close to terminate the application.
When you click Close, you may receive several similar error messages.
CAUSE
This behavior can occur if you use an incorrect version of the Command.com file. For example, this issue is known to occur if you use a Command.com file included in Microsoft Windows 95, dated 7/11/95.
RESOLUTION
To resolve this issue, replace the Command.com file in the Winnt\System32 folder with the same file from another computer that is running Windows NT Workstation 4.0 or Windows NT Server 4.0, and then make sure that there are no Command.com files dated 7/11/95 on the computer. You can also replace the Command.com file on the computer with the same file on the Windows NT installation CD-ROM.
PROPERTIES
Article ID: 245184 - Last Review: November 1, 2006 - Revision: 1.1
APPLIES TO
Microsoft Windows NT Server 4.0 Standard Edition
Microsoft Windows NT Workstation 4.0 Developer Edition
Jul 22, 2014 | Dell Computers & Internet
Only lights up red and does'nt work
The red light indicates a dead battery. Test the battery with a volt meter, to make certain you do not have a bad battery. Even if the battery was "new", it still might be bad. If that does not resolve the problem, contact Shure to have receiver repaired.
Oct 04, 2012 | Shure P4R Microphone
Since updating to IE8 web pictures don't always show and I get this error message: Webpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB6.6;...
> webpage error
Whoever wrote the web-page that you are trying to fetch
has INCORRECTLY created the web-page.
> MSIE 8.0, Windows NT 5.1 ..
Microsoft Internet Explorer 8, running on Windows XP (Windows NT was '4.0', and Windows 2000 was '5.0', and Microsoft just "tweaked" Windows 2000 to produce Windows XP, so you get '5.1', instead of '6.0').
What's the URL of the webpage that does not work?
Jul 13, 2011 | Microsoft Internet Explorer 8
I have application error 302
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Aug 02, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Sony z1 camcorder fails to power up with fully charged batteries
dear try to change the battery ,if still it doesnt work then ...i need nt tell you that ur camcorder is dead ,.. and for that .....
their are circuit protector (commonly known as fuse) in DD board which supplies the power to the VC board ..
and for repairing the DD board to need to take to the service center as their is allot minor soldering work to be done on the board.
Superb Broadcast Equipmentv:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}p:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}v:textbox {display:none;}Slide 1.O {color:#006699; font-size:149%;}a:link {color:#CC99FF !important;}a:active {color:#EBF7FF !important;}a:visited {color:#F2DFFD !important;}
Jun 29, 2009 | Sony Video Cameras
Faulty denon AV receiver remote control
Check with new batteries. Try this site if no luck with fresh batteries; http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
Jan 21, 2009 | Denon AVR-5800 Receiver
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
Oct 05, 2007 | SI-TEX MAX10 NT GPS Receiver
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
