Question about Car Audio & Video
I need a wire diagram of a peugeot partner van radio
sg1972
  • 225 Answers
SOURCE: i need a radio wiring
http://www.installdr.com/InstallDocs/FLM/PDF/356021.pdf
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
Posted on Apr 13, 2011
SOURCE: warning light
how can i get pictures of wot warning lights look like on peugeot partner van
Posted on Aug 23, 2008
alicantecoli
  • 22246 Answers
SOURCE: location of the fan belt
front drivers side wheel arch,then remove the plastic cover ,adjuster is on the altenator ,its a right pigs ear to do
Posted on Jan 17, 2009
TLRogue
  • 99 Answers
SOURCE: Peugeot Partner Fuel Pump Problem.
If that connection is leaking, then that is more than likely the problem. If fuel is leaking out, then air will leak in. When the van is left overnight, the fuel will run back down the fuel line to the tank, leaving air in the pipe. The fuel system must be completely air tight. Try slapping some grease around the connection and see if it starts in the morning. if it does then replace the connector and you have fixed the problem.
TL
Posted on Jan 28, 2009
  • 205 Answers
SOURCE: how do reset service light on peugeot partner van
Perform the following
Turn the ignition off
Press and hold the milometer push button (the button for reset the miles mostly the right hand push button on the dash)
Turn on the ignition (do not start the car!)
Wait for the display countdown to reach 0
Release the milometer push button
Turn the ignition off.
Turn the ignition on and check that the correct mileage till the next service is displayed
Posted on Jun 13, 2009
Hi does any body no where the fuse for the radio is kept in a 53 plate Peugeot partner van,radios stopped working surspect fuse,cheers thanks
If you pull the radio out, the fuse should be slotted into one of the conectors that go into the back of the radio unit, normally a 10a ...well on mine it is which is a 51 plate, think its the same model.
Feb 08, 2016 | Peugeot Cars & Trucks
How do I replace the bulbs in the radio display panel on my 2007 Peugeot Partner Van
you need two brackets .i made a pic .these are normal included,
in your manuel off the radio.puch them in the holes till you feel,
little resistants.then puch bolt sideways and the radio comes out.
am not sure if the bulbs are replaceble. 5a9905e7-8a87-4088-9e2c-7630794e0aa8.jpg
Mar 04, 2014 | 2007 Peugeot Partner HDi
Fitting trailer wiring to peugeot partner van. need to know van wiring colours, dont match trailers wiring colours
Hello, if you have a test light handy with a sharp tip on one side than, start with your parking lights on and check to see which wire it is, if you have a heavy bag of potatoes or similar, you can use this when it comes to the brake lights :)
Feb 18, 2011 | 2006 Peugeot 604
How do your lock in your radio code on a t reg peugeot partner van after entering in the code.
It all depends on the actual MAKE and MODEL of your radio
Most Peugeot radios are made by Blaupunkt , Philips or Clarion so check this site for your actual instructions ( Click on the radio MAKE and enter Peugeot in the Search box)
http://www.radio-code.co.uk/code-entry-help.php
Jul 16, 2010 | Car Audio & Video
Peugeot Partner Van Brakes Drive Shaft
Check both sides of the discs if they are ok.If yes then quite possible that there is lots of brake dust between the discs and pads.
Aug 01, 2009 | 2005 Peugeot 405
Peugeot Partner Van 51 Plate
HI,AS IT IS HARD TO START THESE EXTRA COLD MORNINGS WE ARE GETTING,TRY A SET OF GLOW PLUGS, YOU CAN SEE THEM ACROSS THE FRONT OF THE CYLINDER HEAD,WITH A WIRE JOINING THEM UP,YOU WILL NEED A 8mm SCOKET , FOR THE WIRE, AND A DEEP 12mm ONE FOR THE PLUGS,UNSCREW TO THE LEFT,AND PUT A BIT OF GREASE ON THE THREAD OF THE NEW ONES AS THEY CROSS TREAD EASY,ABOUT 17POUNDS FOR A SET,THANKS.
Jan 03, 2009 | 2006 Peugeot 604
Warning light
Aug 22, 2008 | Peugeot 604 Cars & Trucks
Car Audio & Video Logo
409 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
