Question about Health & Beauty
Sundancer Scooter is fully charged and turned on but does not move when used as usual.
    Scholar:
  • 192 Answers
Hi there! There may be a blown fuse. Check under the seat and check for that, also, while there, look for the kill switch. The unit should not move unless there is pressure on the seat, like when someone is actually sitting down on it. These little clips come off all the time, especially if there is rough terrain that you go over. Take care.. Guy
Posted on Sep 09, 2010
I have a Sundancer wheelchair scooter. I had the rear facing the wall and instead of forward I was pressing reverse and pressing it to the wall. The scooter stopped working after that Now the scooter
hi, please send me the controller and i test it for free, the replacement cost is £45 if if requires repair... you only pay the return postage ..
Regards
gewizrepairs.co.uk
Dec 11, 2014 | Pride Health & Beauty
Why sundancer doesnt move but everything else works
The controller module controls the motor and all the other circuits. Download the service manual from Pride's website. It has a more detailed trouble shooting section.
Jul 22, 2014 | Pride Sundancer 3 Wheel Electric Scooter
Our Sundancer stops moving. It works when we leave
You have been plagued by the infamous Pride Scooter "Time Out Timer" faulty board. In the console there is a timer board that shuts the scooter off if the key has been left in for too long. Only thing is is that these boards quit working properly and wont turn on. Like a posessed demon they are very intermittent in their cooperation - kind of like the wife's cat...
The relay on the board can be permanently bypassed if you know which two pins to jumper together - then the problem will be solved. [ : ` `] <- similar to pins on relay. It's NOT the two close together as those two have power when the key is on.
Oct 23, 2013 | Pride Sundancer 3 Wheel Electric Scooter
Batteries fully charged, scooter gos normal then it wont back up like its dead but it gos on&off. some times it works & other times it wont work
if i had it infront of me i could no doubt soon sort it out ,a absh here and kick their and it will work but without seeing it i have no idea i would suspect a fault with the control lever or the transistorised control panel thats controlling the relays but as stated without having a play with my meter i couldnt say
Oct 13, 2011 | Pride Sundancer 3 Wheel Mid-Size Scooter
Pride Sundancer. Batteries will not charge. both batteries test about 50% charge. When I plug charger in to 110v, the needle on rear of unit barely moves. When I turn on key, charge indicator on on dash...
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Jan 16, 2011 | Pride Sundancer 3 Wheel Mid-Size Scooter
I bought a good used sundancer sccoter and have not used it for 6 months..tried to recharge same and will not take a charge..while plugged in everything works when I take the charge off it reverts back to...
...a scooter is a mechanical thing so we must keep using it otherwise it stops working ..for example ..last year i bought a cd player i didn't used it for 1 yr..now its n working at all..so..i took it to servicng centre ..bt i didn't tell him the problem because if i had told he would lie n charge me more..so..i just told ...".please do some servicing"..so..he only charged me 100rs..!
Dec 15, 2010 | Pride Sundancer Scooter - 3 Wheel - Viper...
Sundance will not take a charge. Breaker is good, front 5 amp fuse is good. All connections are good. Batteries are new. Can also drive away while charge plug is in wall socket. I understand there is a...
On the older sidekick(sundancer) there is an ATO fuse in a rubber boot under the pyramid shaped cover to the rear electronics console that runs to the meter on the pyramid. The newer sundancers have no rear fuse at the electronics tray for the charger. You more likely have a bad charger which is causing an inhibit condition. Usually the scooter will drive away with the charger plugged in until the capacitor drains (1 minute). By unplugging the charger you can get the scooter to run. Check the fuse and the meter connections, then replace the charger with the newer Maximizer style charger with the harness adapter kit.
Nov 25, 2010 | Pride Sundancer 3 Wheel Electric Scooter
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
