Mr. Brammer, Our church has the Panasonic PT-Ax100u projector also and I have done the lubrication of the shaft already and the projector still shuts off. I would like to replace the iris. You said you took pictures when you changed your iris. I was wondering if you could send me the pictures you took and also was there any adjustments involved after you replaced the iris or did everything work fine when you were finished? You said you got into the unit again, did you have problems with the iris again or was it something else? We are a small church and don't have the money to replace the projector any help you could provide would be deeply appreciated. Thank You. Mark Lapre
SOURCE: Akai LCT2701TD SMPS Failure
I have the same problem very hard to work without a print. I found Z3 and its resistors were blown I ordered parts and will keep my fingers crossed
Posted on Dec 24, 2007
  • 16 Answers
SOURCE: Projector self power off
Have you tried looking to see if the lamp has expired? Or could simply be cause by a faulty power supply unit?
Posted on Feb 01, 2008
VOTIT
  • 2071 Answers
SOURCE: Vizio VW42LFHDTV10A
I give you a site for do it your self repair..
http://www.lcd-television-repair.com/
Posted on Jul 07, 2008
  • 86 Answers
SOURCE: Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Posted on Oct 17, 2008
SOURCE: Samsung HLP6163W Problem- TV keeps turning off!
Well, I have had the same exact problem and since my hlp6163w is still under warranty, I had a technician come out to repair it. And...the winner is a bad ballast. The Ballast has also affected the bulb. So, the answer is you need to change the Ballast and the lamp to get the problem resolved. A faulty Ballast will always destroy a a lamp. Sorry for the bad news as this will cost you a total of $400.00 to replace. It sounds like there is a defect in the ballasts that were made for this particular set and a recall should be made. Hope this helps!
Posted on Nov 08, 2008
I seem to have the dynamic iris problem but the lubrication didn't help
You ask the seller, because the product is for them, they know how to deal with the problem. You can also read the instruction.
PANASONIC Lumix DMC-FZ50 Charger
PANASONIC DMW-BMB9E battery
Oct 26, 2011 | Panasonic PT-AX100U-EC DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My PT-AX100u will not turn on. The lamp is new, I have done the iris fix, which didn't help. When I turn it on, the green light flashes and after 30 seconds, it goes into shutdown mode and then one red...
Yes please call me Just went thru the same issue with my customers projector it involves more then typing can fulfill. Thanks Jordan Thomas
910 538 2754
PORT CITY AV
Nov 22, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Ihave a panasonic projection model pt ax 100u
everything you need to know here... http://www2.panasonic.com/consumer-electronics/support/Televisions/Home-Theater-Projectors/model.PT-AX100U-EC
Jan 04, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector PT-AX100U
lamp blown? if not try this first
worked for me
Oct 09, 2008 | Panasonic PT-AX100U-EC DLP Projector
Panasonic ax200e projector
Whats the resolution on the Projector?
Jun 26, 2008 | Panasonic PT-AX100U-EC DLP Projector
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
