Im tryin to put a lock on my wireless router and it keeps asking me for a user name and password and i dont remember it
  • 109 Answers
Most routers use
Username: admin
Password:
Posted on Sep 09, 2010
My NAT type went from open to moderate... How do i fix, and cant remember my uername and password on my wireless g router. i put in my 192.168.1.1 but it askes for my username and password.
The default user name is admin and so it the password you may need to hit the reset button on the back of the router and set the router back up.
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Hi there...wherever you are...i cant get my d link 625 to work..my 2 wire modem failed so i put back in my old action tec and the router wont work..plus it keeps asking me for a password and i dont...
the default password is left empty
the user name is "Admin" then press enter
If you have entered a password follow these instructions:
The following reset procedure will completely restore the default settings on your device, including your password.
Step 1: Locate the reset pinhole on the back of the unit.
Step 2: With the unit powered on, press and hold the Reset button.
Step 3: Hold the Reset button for about 10 seconds.
Step 4: Release the Reset button.
Step 5: The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6: The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for the router is admin and the password is left blank.
go here for further support for you version ( router)
May 29, 2010 | D-Link DIR-625 (790069292637) Wireless...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
How do i put a lock on my router so only i have it
Normally, routers come with a software wizard that will help you set up your wireless and security settings. If this is not the case, you will need to do it manually.
First, you will need the IP of the router. Sometimes it's listed on the bottom of the device, sometimes it's in the manual, sometimes both. If you still cannot find it, try searching for 'defaul ip for XXXXXXX' where x is your router's modle number.
Then, go into IE (or Firefox, Chrome, Safari etc.) and type the IP into the address bar.
It may ask you for a user name and password. Most times the user name is admin and the password is either admin or there is no password.
Since I don't know your exact modle, you will need to do some searching through the web portal (created by your router that you connected to with the IP) for wireless security settings.
Use something like WPA for your encryption method, or WEP if you don't have WPA. Then just give the router a pass key that you will remember.
Save the changes, and you're done.
Aug 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
My linsky connection was canceled and i dont have the disk
Log on to your linksys router page and reset the security key to what ever you want.Just open internet explore and type 192.168.1.1 and when the sign in box appears and if you didn't set up a password Just type Admin for the user name and Admin for the password.
Please take time to rate this a fixya
May 11, 2009 | Linksys WRT160N Wireless Router
Help with ipod touch wireless
Check the name of the connection. The Ipod touch might be looking at a neighbours network.
Dec 27, 2008 | Linksys Wireless-G WRT54GS Router...
Unable to change user name and password on motarola router
Are you using admin for the username and motorola for the password.You must have the i.p right or you woudn't be that far along.
Nov 28, 2008 | Arris SURFboard SBG900 Wireless Router...
Wireless Router
no u need to reset the box again like turn on the device and press and hold reset for atleast 40 seconds and check while u doing this the lights should blinks>and reboot and check
Oct 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
63 people viewed this question
k24674
jasbo
jasbo
