Question about Haier Washing Machines
I have a haier hw- c126otve-u front loading washing machine. The display seems to be stuck on the rince cycle. it beeps and says the end but i can't change the cycle or make it start.
  • 11,896 Answers
The selector switch is most likely faulty and will have to be replaced. You can get parts, manuals, diagrams and more at partselect . com or daysappliance. I do recommend them. Repairclinic . com isn't bad either.
From my experience your timer has gone bad. You can test it with a voltmeter. If by slight chance the timer is good and has power to it, check the control panel for fault. That can be tested as well with a meter.
Posted on Sep 09, 2010
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer beeps at the end of each cycle,must be advanced manually
Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Front loading Haier HW-D1470TVE Door will not open. This inspite of the wash programme having ran and the digital dispkay reads "end". What can I do?
Sounds like your door is locked. Unplug the unit for 30 minutes then plug it back it hopefully it will reset everything and you will be able to open the door. Then after you get the door open you will need to run some tests to see what is the problem. Check the door lock sensor and the door lock mechanism
Feb 19, 2009 | Haier XQG50-11 Front Load Washer / Dryer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    My tricity bendix washing machine flashing and beeping end light
    Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
    Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
    Washing Machines Logo
    65 people viewed this question
    Top Haier Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
    Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
