Question about Lowrance GPS
I have 4 lms350 this week all 4 will pick up any sat. signal. replace ant with new . replaced power cord. unit comes on does not respond about antenna . waypoint are still there. you go to sat tracking no sigal on all four units . could all 4 batteries go bad at once!!! i use these units all the time and there are no MORE i need some help PLEASE. contact thegroupersnooper@yahoo.com or 904 759 1532 Bob Thanks for your time
  • 277 Answers
SOURCE: Will not pick up signal
my guess is that in some point u droped it or something like that the problem sounds like a crystal fault and with u cannot do nothing before u send it to fix try opening the device and see if the wireing of the antenna R fine good luck windman
Posted on Feb 13, 2006
  • 8 Answers
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Posted on Mar 27, 2008
SOURCE: no power supply to gearbox
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Posted on Apr 18, 2009
SOURCE: Magellan Crossover - Need software tools to load waypoints, etc
Download the 2.14 firm ware update - run it it has the usb driver in it - other tools that are on the cd are useless - unless you want to add your own POI's - this unit does not let you see the map files on it - but I am looking for that if I find it I will come back here.
Posted on May 28, 2009
  • 588 Answers
SOURCE: replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Jun 16, 2009
My sat nav in my Audi 2001 A6 cant start route guidance because no satellites are detected
If it never picks up the sat signal then you have a defective GPS. Best to just replace it, the repair cost is equal to a new one.
Jul 22, 2016 | Audi Cars & Trucks
The heater is causing interference with my Satellite TV signal reception. When I turn on the heater my signal begins ti digitize then it goes out. what can I do to prevent this I have the baseboard heater...
sounds like the heater might have a bad heating element or the transformer inside the unit is shorting out. first thing that I would check is to remove the wire plate and check for any burned out wires. ( this unit could be a serious fire hazard ) --- you could always have a electrician come out and check the unit for voltage problems or for about the same price you could go down to your local Hardware/appliance store and just buy a new unit and replace it,, they install very easy and it only takes about 30 minutes to remove and replace the unit --- try and get a unit with the same messurments so you will not have to paint the wall area around the new unit.
now one more quick test to trouble shoot the unit --- try and run power to your satellite system via a extention cord and a different outlet from inside the house. there is a chance that the sat system and the baseboard heater are sharing the same power source and when the heater kicks on ( with its problem ) it is causing a issue with the sat system.
again,,, check out and solve this problem soon as it could lead to a electrical fire.
c...
Jan 30, 2011 | Lasko 5620 Electric Baseboard Heater
Front panel not responding
Please perform the following steps:
1. Unplug the power cord from the unit.
2. Press and hold OK and Cancel buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, please replace the unit. From my experience repairing coast HP OfficeJet 7310xi is almost equal to the coast of a new printer.
:) Dr Tony
Apr 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
Can you put factory sat nav in an X5 when it does not already have it in
Hello There
Yes it is possible to install the factory sat nav in you X5, but apart from the head unit you will also need:
  1. new wiring loom
  2. dvd navigation unit installed at the back
  3. TMC radio unit again at the back
  4. bluetooth unit
All the interior needs to come out i.e seats, floor carpets, door trims.
If you feel brave enough then there are BMW forums which gives you very detailed information on how to to it, but don't expect to get it done in a day or even two, a week is probably realistic time. It took me 2 weeks to do my first 3 series.
Hope this helps. Please don't forget to rate me.
Many Thanks
Jul 12, 2008 | 2005 BMW X5
Why, AGAIN & AGAIN & AGAIN
No power at all, not even for a second. this happens all the time, it usually comes back days or weeks later, it has been over a week now and nothing. I have replaced the power cord in the past when this happened, when the computer starts up again the older power cord will work again??
Thank you for your quick response.
pl
May 27, 2008 | Acer TravelMate 2300 Notebook
Digital sound failed for all channels
If the amp circuit is "toast", you will not get any sound. Get unit serviced
Apr 13, 2008 | Onkyo TX-DS777
Only power button responds, nothing else
Hi there
This unit should still be under warranty - take it to your nearest InFocus dealer.
If no signal is picked up then the Mainbaord is faulty.
Mar 28, 2008 | InFocus IN72 Multimedia Projector
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
GPS Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
