Question about Garden
My JD X475 will run start and run fine for about an hour and then quit. The fuel filter is empty then. If I let it sit for about another hour it will start and then do the same. Could it be the electric fuel pump or the board? I tested the fuel pump wires and at times it was receiving 12 volts and other times the voltage will vary 6, 8, etc. volts. Thanks
  • 183 Answers
Fuel pump could be getting weak, however I recommend to check the vent on the fuel cap. I have seen this many times with the JD machines. The tiny hole in the middle of the fuel cap gets clogged with debris and won't vent, causing the engine to vapor lock. Next time you have this condition, with the engine off, remove the cap for a few seconds and try to restart.
Posted on Sep 09, 2010
1992 Chevy Astro won't run, will start up great with starting fluid, or let it sit overnight.
You need to check the fuel pump pressure and I would change the fuel filter in the process. Sounds like you may have a bad fuel pump.
Sep 25, 2015 | Cars & Trucks
I have JD 935 that runs fine for 10 mins then idles down. Never fully quits running. Changed fuel filters, lines, pump...
check for the cooling fins around the head and block are not blocked with grass clippings/ dirt/dust as it may be tending to overheat and boiling off the fuel in the mixture
Sep 16, 2014 | Cars & Trucks
My x475 jd backfired through carb, fuel lines are
that sounds like a lean misfire... suspect that your fuel mixtures are off... engine numbers would help here
Sep 09, 2014 | Motorcycles
I have a F725 mower. Runs fine when 1st started, after approx an hour it stalls and stops running. Acts as if out of gas. Sometimes you can choke it and it will run a while longer. Changed fuel filter...
Could be ignition module overheating, but then the coke influence doesn't make sense. Once it quits try either a shot of starting fluid in the carb, or tiny bit of gas. If it runs then you know you have a fuel problem. Check to be sure the gas cap is venting and check to be sure you're not getting vapor lock after the motor gets so hot. You could also disconnect fuel line to be fuel pump is pumping. Does it have a kawasaki engine? Beware of some plastic cam gears.
Aug 11, 2010 | John Deere Seat For F710 F725 F735 Riding...
Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Jun 30, 2009 | Husqvarna Zero Turn Mower Z5426
Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
May 23, 2009 | John Deere 420,1020,2010,2020,2510,2520...
2003 kia sorento quits running wont start back
Did you try changing the Fuel Filter?  That did it for my Kia Sorento 2004.
Jan 14, 2009 | 2003 Kia Sorento
Engine quit while driving
You will need to check every ground wire! Remove and clean each one. There are so many, too many to list! Frankster016
Oct 25, 2008 | 2005 Ford Ranger
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
