Just need instructions for magellan 4 drawer file cabinet, i'm putting one together.
Metal file cabinet problem
sometimes wd40 works on stuff like that too
Jul 28, 2012 | Hon 534CQ Vertical Metal File Cabinets...
I need instructions manual for Essential Home 4-Drawer Chest
I have a essential home 4 drawer chest, without instructions. Model number 634102k.
Aug 29, 2010 | Office Equipment & Supplies
How to make swing machine desk
All you need to buy for a sewing machine desk is two 2-drawer file cabinets and a piece of plywood. Just make sure the plywood isn't flimsy and get a piece the width of both cabinets plus an extra 2-3 ft. Lay it on top of the file cabinets and put the cabinets under each end of the plywood leaving the extra 2-3 ft area open in the middle for your chair. You can purchase the cabinets at any Goodwill. They seem to always have a supply of them. You might even find an inexpensive sewing table there! Good luck.
Aug 24, 2010 | Singer 3116 Simple
Need instructions to put together Davinci Parker dresser. Item # 02f162, SKU:K5155F
Here is a link to download the instructions for the Million Dollar Baby DaVinci Paker dresser: Model K5155:
http://www.milliondollarbaby.com/system/pdfs/60/original/K5155_Parker_4_Drawer_Dresser_-_10.29.09_HS_.pdf?1256922917
Jan 09, 2010 | DaVinci Parker Collection - Crib & 4...
I have a set of blum tandem kitchen drawers and no instructions and I need help
The following link, has cabinet and drawer specifications, for the Blum Tandem 562H Series, and Tandem Plus Blumotion kitchen drawers,
http://www2.woodcraft.com/pdf/77B74.pdf
[This is a PDF file download. Give it a few seconds to download after you click on the link.
{Or copy and paste the above link into your address bar, and press the Enter key)
Viewing the setup dimensions for the drawers and cabinet, and where the template goes, may help you.
I need specifics on what help you need. Ask away.
Sep 07, 2009 | Dmm Blum Tandembox Sink Drawer With...
LG Tromm - soap drawer is stuck and will not open
This is caused by the "Fabric Softer" removable tray inside the drawer getting stuck in the top of the drawer cabinet.
Solution:
1. Unplug machine
2. Remove four sheet metal screws and plastic plates from top of back of machine that hold the "lid" on (perhaps yours is different and only has two screws, but that's your world :) )
3. With the palm of either hand hit the both sides of the lid of the machine at about a 45 degree angle towards the back of the machine until the lid slides back about 4 inches
4. Gently remove lid (will lift off easily if you've freed it correctly)
5. On left you'll see a white box which is the cabinet for the drawer. Carefull pull the black wire from it's retainers
6. Lift up the three clips on the right side of the cabinet that hold it together
7. In the back of the cabinet, grab ahold of the plastic piece that doesn't have a hose attached (unless yours does, in which case figure it out yourself :) ) and gently pull up until you can see the cabinet coming apart in the back.
8. When you have enough clearence push a screwdriver through the opening you've created while lifting on the back of the cabinet apart, and PRESTO! The drawer will pop out.
This will happen everytime from now on if you do not remove the the "fabric softner" tray from the drawer. It is a design flaw that will happen to all models eventually. If you must have that little tray, then find a solution that works and post a follow up here (I imagine it will involve a bench grinder :) )
HAPPY WASHING AND BUY AMERICAN!!!
Jul 14, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
153 people viewed this question
jasbo
jasbo
