Question about Keurig B50 Coffee Maker
I neeed a replacement reservoir for my Keurig machine it was sitting to close to my canner and it melted from the steam.
You can call call Keurig directly at 1-866-901-2739..
Posted on Sep 14, 2010
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
I bought a refubished pressure cooker there is something funny the presure release device sits to loosely on top I wonder if its broke? Or where can I get a new pressure release device to replace this...
It should rattle if it is a pressure cooker This item will be round and should have a hole
in it. steam will escape from this hole as its cooking and it will rattle. It is a weight.
If it is a pressure canner it will have two items,
a pressure relief and a pressure gauge. Many had wing nuts which held the
lid in place such as mine has.
Wikipedia has a nice treatise on pressure canners as a reference.
hope this helps.
Mar 05, 2011 | Microwave Ovens
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Nov 08, 2010 | Keurig Platinum B70 Coffee Maker
Keurig when drawing water in takes a long time then turns off, sounds like it is clogged in some way
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. Hope that helps! Best of luck...
Feb 01, 2010 | Keurig B60 Coffee Maker
When trying to brew a cup of coffee it drips slow like it is clogged
Hi, RICHBURG511. Sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up (calcium) from the minerals normally found in your water. Do you use regular tap water or filter it in any manner?
When was the last time you de-scaled your Keurig? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
Here’s the ‘poop’ straight from Keurig, direct. Just follow the links.
Good luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! -
hslincoln
Dec 05, 2009 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
264 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
