Question about Aurora Electronics PR620 Calculator
Replace paper - Aurora Electronics PR620 Calculator
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    I'm getting an error code of W8102. Can anybody out there tell me what that means??
    W8101/8102 - Print media position warning
    The paper over the platen lies too near or too far from the carriage home position
    when fed into the printer.
    Cause>
    The paper on the platen was too close to or too far from the carriage home position
    side when paper was fed.
    <Probable faulty component>
    The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
    unit, encoder sensor unit, linear scale, carriage controller, head controller, system
    controller.
    <Action>
    1. Paper setting check:
    Reset the paper if the setting is not correct.
    2. Paper check:
    Replace the paper when any stains or pre-prints are found.
    Straighten or replace the roll media when the roll of paper is ruffled.
    3. Cassette unit/cut-sheet feed unit:
    Replace the faulty paper feed component when the paper feeding is performed
    correctly in all parts except where the error occurred.
    4. Check the linear scale:
    Visually check the linear scale for abnormal conditions, such as stains or damage.
    5. Replace the carriage unit.
    6. Replace the head controller.
    7. Replace the system controller.
    May 18, 2010 | Canon BJ-W9000 Copier
    Codigo C7760 de una Kyocera kilometros 1635
    C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
    Jan 19, 2010 | Office Equipment & Supplies
    Is the Paper Feed Kit 1 a replacement paper tray?
    The paper feed kit 1 is a new feed roller and a new sep. pad to install in the paper tray.
    Aug 11, 2009 | Office Equipment & Supplies
    Cannon printer pixma mp470 paper jam
    hmm, could you be more specific?. But I'll try to solve anyway
    Paper jam error occurs because:
    • Paper end not detected by paper sensor; set paper properly and press Stop/Reset button
    • Paper sensor broken; replace paper sensor
    • Drive assy broken; replace drive assy
    But before it all please check if any broken paper or another material is in paper path blocking the paper to reach paper sensor.
    Nov 09, 2008 | Office Equipment & Supplies
    Paper curl
    Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
    If it is the entire paper replacement of the fuser will likely resolve this.
    If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
    Nov 03, 2008 | HP LaserJet 4 plus Printer
    "printer error - check paper" after cartridge replacement
    First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
    Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
    Aurora Electronics PR620 Calculator Logo
    Top Aurora Electronics Office Equipment & Supplies Experts
    k24674
    Jim Keysor
    ka4iup
    ka4iup
    Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
