SOURCE: 14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
SOURCE: power windows and indicators have failed at same
Even I am having the same problem. In addition to power windows and turn signal, the seat belt sign is also not working. Let me know if you find otu something and same with me, if I figure something out I will let you know
SOURCE: New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
when i turn on my drill amoked comes out hohw can i fixed it????
SOURCE: Charger is dead (UC12SD). I checked the fuse, it's
While the above advice is correct I curently have the same problem.
I have measured the secondary of the transformer and found it to be dead, no volts.
This transformer has a center tap that I guessing is 24v centre tapped. If any one has had any experience with this area would you please advise to [email protected]
Thanks
Doug
