Question about Gateway FPD2275W LCD Monitor
After connected to brain no picture on monitor- short period only then it goes completly black
  • 11,361 Answers
Look for bad caps: http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Be REAL CAREFUL when opening up the case, watch out for th ribbon cable attached to the front bezel.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 09, 2010
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Model hp1702 power supply ok inverter ok but connect the lcd panel socket suddenly off's? the green indicator light ...
monitor old very very old. 13 years old in fact.
this is a CCFL back lamp old monitor
so is the back lamp dead, that it.
does a flash light pointed to the face show a working
front panel menu button OSD data now? this is first to do.
OSD is always first then check the backlamps for DEAD.
that green lamp actions are covered in the 1703 manual
did you read that ?
i guess you meant the green LED goes dead? suddenly>?
ill read it to you.
https://www.manualslib.com/manual/767564/Hp-L1702.html?page=44#manual
that is not some simple monitor no,
it has its own processor inside, and that needs power too.
it must convert VGA video RGB top LCD data., all non trivial.
page 7
Power Indicator: Green - Power On mode.
Amber - Power Saving mode.
Blank - Power Off Mode
so if it turns its self off
that means the Brain inside sees gross errors.
or the brain side lost power.
there are many tests.
in a pro show we check all power busses, if the black lamps work
the connect up i2c to the I2c port and scan it for errors
this is what we must do to see if the BRAIN inside sees gross errors.
there is no other ways. to do that.
or if connected the CCFL tubes the monitor turns off
well the CCFL tubes are shorted. and if are, then the brain
was correct to shut it off or risk a fire.
see? it really is very smart.
Aug 17, 2017 | HP L1702 17" LCD Monitor
Monitor goes black
You may have failed backlight inverter circuits, power supply, lamp assemblies. First place to look will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 20, 2010 | Proview PL926WBi 19" LCD Monitor
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
May 06, 2010 | ViewSonic VA1703wb Monitor
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Does not turn back on after switch off when warm
The monitor turns on, flickers and then goes black.
Dec 06, 2008 | Computers & Internet
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
