Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker over the oven microwave, model no. jmv1440bh04. Last week all of a sudden it start sounding like it is only running half power. Once it quit all together but started working again after waiting a little while.
  • 4 more comments
  • parose Sep 09, 2010
    Is the fuse you are talking about a 250v, 20 amp fuse located upper right behind the grill? Seems like if the fuse was bad the microwave would not run at all, no?
    As you can tell I'm not very knowledgable about what I'm doing but the best that I can describe it is that it still runs and heats but sounds like it is running in slow motion. It was running fine then all sudden the pitch in the noise the microwave makes dropped. The fuse is white and has a black mark around the center, is this an indication it is bad?
    I replaced the fuse but it didn't help the problem. I noticed the turn table runs slow as well so I tried turning it off to see if that would change anything but it didn't. Testing the power supply and magneto, whatever that is, is above my level. I can replace the microwave myself but it is really not that old, maybe three years. I hate to replace it if it is something simple and I also don't want to call repairman and spend more money than the microwave is worth. Any other thoughts?
    I'm not sure what you are talking about when you say, "Is the setting on high? What setting? Where is it located? How would the setting just suddenly change when the microwave is running? I just check circuit board and there don't appear to be any burn marks or swelling/ leaking of electronic parts. I opened up the bottom and there is no belt for the motor to the turntable. It appears to be a small direct drive. Again, checking the power supply is above my level of competance.
    Thanks for all your help.
    Yes! Eventhough I was unable to pinpoint the problem I was able to rule out that the problem was not something simple. Thanks for all your help...Pat Arose
  • 11,896 Answers
If you have it on high setting and it is not running on high, change your fuse first. You may also test the power supply and magneto if needed. The power supply may be wearing out. The magneto is what heats it up but if that was going you just would have much heat at all or no heat but microwave lights and turn table should not change
Posted on Sep 09, 2010
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Sep 09, 2010
    If it was completely burnt out it would not work at all. The power supply is what provides power throught the microwave. This is one of the most common devices to fail in any electronic. Then there is a relay on the circuit board. Inside there are contact points that engage and disengage depending on if power is provide to that part of the circuitry system or not. This can wear out and work sometimes and not others.
    Then lastly there is the magneto. This provides heat waves.
  • Nate Stansfield
    What exactly is the unit doing or not doing?
  • Nate Stansfield
    Yes your fuse will need to be replaced.
  • Nate Stansfield
    Is the setting on high? Have you removed the cover and looked inside to see if any of the electronical parts are swelled up or leaking? Or look for any burn marks on the circuit board? How about the belt and motor on bottom? You can test power to the motor to see if it is getting full power. If it is and motor is not spinning fastly enough, it may be worn. If not enough power is going to the motor, than power supply or capacitor/resistor issue.
  • Nate Stansfield
    Not a problem. Let me know if there is ever anything else you need help with. Thank YOU.
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile spacemaker stopped heating all of a sudden everything else works. vent turning plate etc.Model # JVM1660CB Serial # F2909188S should I fix or buy new one...and which is the new model?
You may have a fuse that burned out. not everything runs on the same circuit . If its not the fuse than its probably the mega-tron, and that's big money. Check the fuse first. good luck DFD
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
260 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
