Question about Refrigerators
Ice auger will not run - Refrigerators
  • 101 Answers
Auger motor bad
Posted on Sep 10, 2010
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Jiffy ice auger won't start if cold.
I
Hello. I'm kind of "out on a limb " here but my older chain saws and my Jiffy auger's the same. I use the highest octain fuel I can get (at the pump) and I think it helps. These old motors were made to run on real gas.
builderdale
Jan 08, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Why doesn't my ice maker work?
You do not list model number, so this will be very generic. If you have cubes in the ice bin, and when you try to dispense them the duct door opens and the auger motor runs, check the auger in the ice bin itself. Check where the spiral auger meets the plastic part on front of the auger. Drive part likely seperated.
Nov 21, 2008 | Refrigerators
Ice dispenser
first check the connection at the auger motor, sometimes they come loose, otherwise it's one of two things, the auger motor itself, (check for 110 volts while calling for ice) or the microswitch in the front door panel. usually the auger motor.
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
