Question about Hitachi Deskstar 7K80 HDS728080PLA380 80GB 7200rpm 300MBps Serial ATA II Serial ATA/300 I... (0A30356FT) Hard Drive
In my pc hds728080pla380 hard drive was in master mode. when I put anothor sata drive, Hitachi drive got in to slave mode. when I removed other drive Hitachi drive did not come to master mode. how can I change it to master mode again?
SOURCE: Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
Posted on Jan 23, 2008
  • 9 Answers
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Posted on Mar 20, 2009
  • 153 Answers
SOURCE: Sata Hard Drive not detected on Bios
I would tend to agree that if the ports are set to autodetect it would suggest that they are looking for drives, but go through every item in your bios just to make sure that there isn't some obscure spot where the port is turned off.
If your bios is not detecting a drive your o/s is not going to find it either, and Linux will likely have the driver it needs when you go to load it. What's more, if it doesn't, you're rather hosed until it does.
If everything looks right after checking and rechecking and sleeping on it and checking again, but your bios still won't find the drive, take the drive back and get it replaced.
Posted on Apr 30, 2009
preachw996
  • 1179 Answers
SOURCE: pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
Posted on May 23, 2009
  • 742 Answers
SOURCE: How to make sata hard disk a slave???
Look at the jumper settings. These jumpers are located near the data cable and the power port of the hard disk. Usually by default, this jumper is set to "Master". To make it a slave, just remove the black or blue jumper or please refer to the jumper guide table printed in you hard disk's label.
Posted on Dec 29, 2009
I purchased my old computer in 2009 and it came with the Hitachi HD, HDS721010CLA332 (0F10383). That computer has failed and I purchased a new HP Pavilion. Can I take the old Hatachi HD and make it a slave...
Hi there.
Since your hard drive is a SATA drive, there is no such thing as master and slave drive anymore.
All you need to do is plug it into your new computer (assuming there is an extra slot for a hard drive in there). You will need an extra plug from your power supply that will plug into the hard drive as well as a SATA cable that will plug your hard drive into the motherboard.
Another thing you can do is get an external hard drive enclosure and put it in that. Just make sure you get a SATA one, not an IDE one. I hope this helps.
Sep 08, 2011 | Hitachi HDS721010CLA332 Deskstar 7K1000C...
How do I slave HDT721050SLA360 500GB 7200rpm
This is a SATA drive, in the SATA configuration each drive is on its own, alone on the cable, no master / slave configuration.
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
How to set jumpers on a hitachi hard drive
Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
Aug 18, 2011 | Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
I bought a hard drive HITACHI Deskstar HD31000 and want to know how to tap into the power of the PC, or is that enough to connect to SATA cable only? and also how I would put it in slave, because it is...
The SATA hard drive has two cables, one for power and the other is a data cable.
There are no jumpers on a SATA hard drive to configure as a Master or Slave. this is done by configuring the SATA controller.
Oct 08, 2010 | Computers & Internet
Hi where is the jumper to put the hard drive into slave position on a hitachi TRAVELSTAR HTS541080G9SA00 ? I cannot find it Many thanks best regards
Hi
There are no jumpers to set on a SATA drive since they all use individual interfaces with the motherboard.
All you can do is connect the drive you want as master to the first SATA header,slave to the second,and then set the boot priority in BIOS.
They don't have jumper pins like the old days.
Post again if you have questions,and if this helps would you rate my post?
Bob
Aug 22, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
Computers & Internet Logo
115 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
