Question about First Alert SA302 Dual System Smoke Detector
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
  • 8,457 Answers
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
Posted on Sep 09, 2010
How to get the battery out on a BRK first alert SC9120A.
First disconnect the smoke alarm from the AC power. You may need a flat blade screwdriver to separate the alarm unit from the mounting bracket. Position the screwdriver between the locking pin and the mounting bracket and turn both the smoke alarm and the screwdriver to the counterclockwise (to the left). If this pin isn't in place, you should just rotate the alarm counterclockwise to disengage it from the base. Next check if the battery compartment locking pin is in place. Use the flat blade screwdriver to pry the head of the locking pin out of the alarm. (It goes through the black dot on the label.)
If the lock is out, the battery compartment should pivot open when you press the lever. You'll want to press it so that it compresses against the battery compartment. For pictures to go with this explanation, see the manual. It's available here: http://hsbuild.com/assets/pdfs/ESF650_Manual.pdf .
I hope this helps.
Mar 14, 2018 | Home
Smoke alarm beeping and can't find a battery compartment, wired
Some smoke detectors don't have a battery compartment they are called 10 year smokes which never last that long. Take off the wiring harness sometimes there is a door there to access the battery compartment, if there is not compartment check the sides of the unit for a pull out latch. If none of those exist you will have to buy a whole new unit, I would recommend staying away from a 10 year and get something replaceable.
Jul 04, 2017 | Home
My kidde model kn-cosm1b alarm goes off and ask to check battery but the battery is good
See the instructions for that model. Sometimes you need to wait a minimum period of time between removal of the old battery and installation of the new one. Also make sure you are positioning the battery correctly; sometimes batteries can be put in backwards easily. It is also possible that the device is just bad and needs to be replaced.
Sep 09, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Fire alarm beeping after battery change
you need a good quality fresh battery, cheap or old batteries are not strong enough
Jun 27, 2014 | First Alert Brk / First Alert Smoke...
Battery connection on new alarm Light Your Way Smoke and Fire alarm
If the battery will not make a connection, it may not be installed properly. The connector requires firm pressure.
My First Alert instructions say to "press and hold the test button on the cover for 5-20 seconds, or until the alarm sounds".
Nov 07, 2013 | First Alert Sa304Cn3 Smoke Alarm Escape...
Two first alert smoke detectors go off for no reason. All are on 110 with good batteries. Have had these for approx. 12 years with no problems until now when 2 of the 7 have gone off many times in the last...
There may be dust built up in the sensing chamber. This can cause alarms to go off for no reason. Try vacuuming the alarm off particularly around the sensor if the cover is removable. These alarms should be replaced however, as they are more than 10 years old.
Apr 07, 2011 | First Alert Brk / First Alert Smoke...
Smoke alarm beeping
If after replacing the battery the alarm is still beeping, the smoke alarm is bad and needs to be replaced. Hope this answers your question. Best of luck!
Greg
May 23, 2009 | First Alert SA302 Dual System Smoke...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
First Alert SA302 Dual System Smoke Detector Logo
1,024 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
