Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My whirlpool ultimale care ll imperial series 9 cycles 5 speed combination, washing machine. The inse cycle stopped working.
mikedurland
  • 481 Answers
SOURCE: Whirpool Ultimate Care II washer Imperial Series spins at low speed
Posted on Aug 12, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you need further assistance. I hope this helps you.
Posted on Jun 30, 2009
SOURCE: whirlpool imperial series 2 ultimate care washer
I had the same problem with this washer. It was the lid switch.
Posted on Dec 01, 2009
washdryman
  • 154 Answers
SOURCE: washer is a 2002 whirlpool model ultra care
AS LONG AS IT IS WORKING OK YOU ARE FINE SOMETIMES THE TIMERS ARE LOUD
Posted on Feb 07, 2010
I have the ultimate care ii imperial series quiet wash. Black clothes come out with lint and white marks on them. WHY??
You may have washed a tissue or paper towel by accident. Powder detergent or overloading can cause this .sort lint givers( towel,chenille) from lint takers (corduroy, synthetics) low speed cycles may not dissolve in low or delicate cycles. Always use he detergent it can minimize these effects
Jul 25, 2015 | Washing Machines
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
I have the Imperial Series Quiet Wash I My washer goes off on every cycle and I have to press the lid for the washer to kick in
Probably the 'lid switch' needs to be adjusted. This is the switch which stops the machine when the lid is lifted. Should be a simple fix ...Good luck.....Nomess
Apr 20, 2010 | Whirlpool Washing Machines
Whirlpool washer stops in the middle of cycle does not rinse and
If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
Aug 15, 2009 | Washing Machines
How to replace timer control on Whirlpool WTW5810SW0
my whirlpool - Ulitamte Care II, HD, Super Cap.Plus, 8 cycle, 5 wash/spin combo washer timer will not rotate to the drain cycle on all cycles. THe timer stops turning, and just before stopping it makes a load sound for a timer.
May 09, 2009 | Whirlpool Washing Machines
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
