Question about OKI B6300 Laser Printer
My printer display please reboot printer (010-349)
    Problem Solver:
  • 13 Answers
Change the Fusor
Posted on Sep 21, 2010
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
I wanted to make 10 copies of a document using the glass. The printer froze at 3 of 10. I pressed cancel, the display showed canceled for almost an hour. I then pressed the power button now the display...
It is my pleasure to guide you.
Is it hooked up via USB or parallel?
If parallel, then the computer must be turned off to hook it up. If USB, it does not matter if the pc is running to hook up.
One thing that you can count on, it rarey hurts to shut down/unplug a printer. Sometimes that is the only way to reset the software and trouble shooting software in the printer. I use to take care of pcs/printers and sometimes did just that.
Leave the printer unplugged (if USB) and reboot the pc. Then plug it back in again, letting the OS cycle the addition of the printer.
If parallel, shut down the pc. Unplug the printer and reboot and shut down completely. Plug the printer in again and reboot.
Good luck and please post back that you are successful, giving thumbs up, or so I can be more help.
Jun 10, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
OPEN DOOR
Try doing an nv ram
1. Turn the printer off
2. Hold down the select and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work it could be an actual sensor that is damaged.
Al
Eliteprintersolutions@gmail.com
Jul 09, 2010 | HP LaserJet 3050 All-In-One Printer
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing...
Never ever touch the printer while upgrading the firmware.
You now need to replace the formatter
  • DO NOT power cycle the printer or the PC during this process or the printer may become unstable and or unusable without further attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
  • During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display "Printing Document" and will change to "Erasing". After a short while, the LCD display will change to "Programming". After a short while, the LCD will display "complete : )" and the "Ready" LED on the printer will be flashing. The printer will automatically power cycle to reboot and will make noises similar to power on.
Jan 28, 2010 | HP LaserJet 3020 All-In-One Printer
Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
Aug 14, 2009 | OKI B6200 Laser Printer
Hi, i have a problem with color laser printer xerox (can't remember model), the problem is please reboot printer error number 004321, please help to solve. thanks
You should обратпться in service service. Тhe temprechure of block of the fastening insufficient, for functioning(working) the printer. This can be an usual preventive maintenance. Under thermo by sensor is going to the toner and the temperature is displayed untrue. Good luck you!
Dec 26, 2008 | Office Equipment & Supplies
Hp PSC 1610 all in one printer
I may need a little more information to understand the exact nature of the problem. First, it sounds like the printer worked normally until the computer was rebooted, and then it stopped working completely...is that correct?
Do you get any error messages, either on the printer's display panel or on your computer? There should be a printer icon in the bottom right corner of your computer's screen. Does it look "normal" or is there a yellow triangle with an exclamation mark in it?
Frankly, rebooting the computer shouldn't result in the printer becoming completely non-responsive. My first suggestion would be for you to unplug the printer's power cord, wait about 10 seconds, and then plug the printer's power cord back in. Leave all of the other cables attached (USB connection to the computer and such). Make sure the computer is on and running while you do this.
Let the printer completely power up. It has to go through a start up routine, more or less the way your computer does. See if you can get a connection afterwards. Sometimes a glitch will occur and rebooting the printer will clear it.
If this doesn't do the trick, please post back more details about the nature of the problem. Thanks.
Oct 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Samsung SCX 4100 Printer
just check the feeder is working normal, and there was no stucked parts on the roller area.
Aug 25, 2008 | Office Equipment & Supplies
OKI B6300 Laser Printer Logo
1,219 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
