Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
My compressor also will not build over 20 lbs of pressure. Air is coming out of the Oil fill cap air vents. Is air supposed to be coming out of these vents?
  • Craftsman Master
  • 885 Answers
You should not have air coming out of the vent cap. From what you've stated here I believe your piston rings and/or cylinder are damaged to where air is getting past them and going back into the crank case. It's possible you have a frozen valve plates so check them on your way to the piston and cylinder.
Posted on Sep 09, 2010
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
Pressure inside oil tankl
All air compressor will build pressure in the oil reservoir. This is caused by blow-by past the piston rings. The reason all compressors have this is due to the relatively slow rpm that the compressor crank is turning. Unlike a car's engine that is turning so fast the compressed gas doesn't have time to leak by the rings.
To deal with this problem air compressors have a special oil fill cap that alows the pressurized air to be vented out of the oil reservoir chamber.
There are three reasons that you are having this problem. The first is you have a clocked oil cap vent. Second is you have the wrong type of oil cap.
The third is the bad one. If the problem is unrelated to the oil cap then it means there is more blow-by then the vent cap can handle. This would indicate that you have worn or broken rings and/or worn cylinder wall.
If your compressor is not old (low hours), then take a close look at the cap. If it has more then 2000 hours then you will most likely need to rebuild the compressor, depending on the make and model.
Hope this helps and good luck.
Dec 12, 2009 | Air Tools & Compressors
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
831 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
