Question about Whirlpool RBD305PD Electric Double Oven
I HAVE A RBD305PDB DOUBLE WHIRLPOOL OVEN AND THE DOOR GLASS BROKES AND FALLS TO THE FLOOR. THE OVEN IS COMPLETELY COLD. WHAT MIGHT THE BE THE PROBLEM?
SOURCE: Need to verify/reset oven size on a Whirlpool 307PVS double oven.
Found the electronics package manual on another web site and downloaded it.
Posted on Dec 15, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
SOURCE: I HAVE A RBD305PDB DOUBLE WHIRLPOOL OVEN AND IT
WHEN MY OVEN KEPT BEEPING AND LATER IT WOULD NOT OPERATE, I CALLED THE LOCAL COMPANY WHO SOLD MT THE OVEN...(KITCHEN CONCEPTS), THEY FORWARDED ME TO THEIR SERVICE COMPANY WHO CAME OUT AND LOOKED AT THE ERROR CODES AND SAID, "THERE IS NOTHING BUT BAD NEWS) THE CIRCUITS IN THE OPERATING CIRCUITS HAVE BEEN BLOWN OUT BY SURGES...IT WILL COST $538 TO REPLACE THEM....HIS STORY WAS THAT IN OUR NEIGHBORHOOD, THERE ARE A MULTITUDE OF SURGES...MY QUESTION IS WHY THE HELL DOES WHIRLPOOL PUT OUT A $1100 OVEN WITH NO PROTECTION FOR SURGES....CHECKING ON THE NET, I SAW MANY BAD FEATUIRES ON MY OVEN....DON'T USE THE OVEN CLEANER AS IT WILL COOK YOUR CIRCUIT BOARDS AND SEVERAL OTHER....WHAT A PIECE OF ****....I AM GOING TO WRITE THE COMPANY AND *****....TO NO AVAIL, THANK YOU FOR YOUR HELP....
Posted on Mar 06, 2010
SOURCE: Whirlpool double oven Model#: RDB305PDB12
there is a tco (thermal cut off) part under the control pannel.
the local electronics store had them but not the right temp. choices for me where 1 degree cooler or 7 degrees hotter. the part was under $4. online for the right temp they wanted $15.75 s/h. In my oven it was inline with a black wire. both ends had the knife quick connects and is covered in a thick clear plastic. Be carefull. I dont know how but the ribbon cable for the control pannel broke while i was working on it. :( this $4 part did bring the power back on but because of the cable issue no keys worked.
Posted on Aug 06, 2010
  • 84 Answers
SOURCE: whirlpool double ovens error message e6 f2
E6 F2 is always a problem with the control board. It can be fixed quickly and reliably at www.fixyourboard.com
Posted on Nov 03, 2010
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
I HAVE A RBD305PDB DOUBLE WHIRLPOOL OVEN AND IT WON'T ACTIVATE THE BAKE/TEM/TIME FUNCTION AND IT SHOWS EITHER E2 F6 OR F2 E6 IN GREEN....
Mar 05, 2010 | Whirlpool RBD305PD Electric Double Oven
THE INSIDE GLASS BROKE
part number is 4449259 of the inside glass you will pay around 60.00 for it good luck
Jan 12, 2010 | Whirlpool RBD305PRS Oven
Clean between door window panels
Sorry this is the only way to clean in there but if you take the door completely off and set it on a drop cloth Then take it apart it makes it a little easier
Jan 26, 2008 | Whirlpool GBD277PD Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
