Question about Star 301HLD Deep Fryer
The item will turn on and begin to heat but it then starts to heat and takes a very long time to get to the temp set. Then once we add the items to fry it stops heating..we cannot tell if it is shutting completely down or if it is just struggling to stay at the temp needed. The light turns on so it is staying on just not staying at the temp needed.
  • Star Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If this is electric then you have a burned out element...
if this is a gas unit,,,
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 09, 2010
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
My panther 110c wont turn over.
So, do you mean no starter engagement? If so look for connection issues, actually inspect for looseness, and corrosion. Look for GROUND issues, sometimes you have to run grounding wires between items and the battery.
If you mean that the engine does not FIRE, but the starter is turning the engine over....look for ignition based heat damage. Temps affect these items.
Sep 09, 2012 | Cars & Trucks
I am unable to record it showing lock symbol and it changed in to japaneese language so i am unable to do something pls help me
To reset the settings back to English:
1. Set the DM-10 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-10 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-10 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Download all files first before because this will reset/format your DM-10
Feb 28, 2011 | Olympus DM-10 Digital Voice Recorder
GE Model GSS25JFMWW, started with the ice maker not working, then the water doesn't work half the time. Now the freezer and Fridge both stop working, and out of nowhere the will start again after a couple...
Hi and welcome to FixYa, I am Kelly
The ice-maker not working was a sign that the freezer temps were rising above 14 - 16 deg F. There ice-maker has an internal thermostat that activates the harvest cycle when the temps reach around 15 deg F. If the freezer is warming up it will never make ice.
What is most likely causing the recent symptoms of the unit shutting of and not stating for a long period is either an intermittent defrost thermostat (
The unit has a timed defrost cycle to START the cycle but there is a 60 deg F thermostat that opens to terminate the defrost cycle. If the defrost heater does not work the unit has to slowly warm up toward room temp without heat to reach 60 deg F for the defrost cycle to terminate. This can take a very long time if the freezer is more than 50% full as the contents will keep the temp below 60 deg F for an extended period.
I suspect you have a defrost element failure. Item 230 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357329#d22357329
You should read resistance across the defrost heating element. No resistance = open element.
There is the very very remote possibility that there is a problem with the main board. Item 801 this link:
Since the unit works once defrosted I doubt the main board has failed.
There is a thermistor that is item 241 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357332#d22357332 that can possibly cause the problem.
Thermistor Image:
http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNTIwMDFYNTVSVy9IRUcvc290b2hwdHJhcC8%3d
If the defrost heating element is good then this would be suspect #2.
I hate to use someone elses material in a response but this one is so good that it is a must read:
http://www.appliance-repair-it.com/refrigerator-thermistor.html
Bottom line... I still think you have a defrost heating element problem at this time.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | GE GSS25JF Side by Side Refrigerator
Whirlpool refrigerator getting hot on frame where doors close.
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Sep 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The divider that seperates the freezer from the fridge get hot to the touch, heats up the fridge door gasket
Hi, Welcome to FixYa.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
macmarkus :)
Jul 31, 2010 | Maytag MSD2756G Side by Side Refrigerator
Bar between freezer and refrigerator is hot model SCD 25 TL
Hi, Welcome to FixYa. I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. **Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor. The amount of heat can be determined by several factor's such as, 1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip. 2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip. 3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter. 4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. macmarkus :)
Jul 22, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Whirlpool Cabrio top load washer won't start now but it first started by giving LD code when would wash only heavy items like full load of towels or bedding (all others ok). If I let it sit for awhile...
we ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
One day, it just stopped giving us locking problems.
Sep 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lost instructions for Lexon world time clock model Planete
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to
blink; press "adv" repeatedly until hour AM or PM is correct. Now
press "mode" so that the minutes blink, and use "adv" to get the
minutes right; then press "mode" so that the next item begins to
blink; use "adv" to advance until it is correct, then press "mode"
so that the next item blinks, and so forth until you're all done.
Finally, press and release "set".
Aug 10, 2009 | Watches
Dm-20 displays Chinese
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
Jan 08, 2009 | Olympus DM-20 Digital Voice Recorder
Star 301HLD Deep Fryer Logo
159 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
