Question about 3Com SuperStack 3 4228G 24-Port Ethernet Switch (0662705446844)
When i power on the 3com switch 4228g In Self Test Alert showing Orange Light flashing on port no 25 and 26
  • 71 Answers
SOURCE: Anyone seen ths before?i
when it flashes it usily means its connected if it dosent work at all you should get a new hub
Posted on Aug 12, 2007
SOURCE: inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Posted on Jan 01, 2009
  • 59 Answers
SOURCE: 3Com 3c17304 port 25 up not connecting
Well I think the port is bad, I had one that did something similar to your problem. I got on the 3Com website and submitted and RMA request and they upgraded my with the newest model. But if yours is still in stock they will replace with the same type. That is what I would do. Hope this helps ya.
Posted on Feb 26, 2009
  • 18 Answers
SOURCE: i cann't connect to my switch
Your superstack 3 should have a 9 pin male connector at the back labeled "console port" you need to connect this to your serial interface on your pc or laptop. With 3Com you also need to set your baud rate to 19200 as this the default for 3Com.
Posted on Oct 19, 2009
RaidX
  • 632 Answers
SOURCE: i am looking for 3com 4228g default ip address
It depends what device on your local network it is
It may be 192.168.1.1
or 192.168.100.1
You may have to do a network scan and locate its exact network IP
Posted on Jun 24, 2010
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
How reset 3com 4228g switch
If I remember correctly, there is a tiny hole at the back or on the side. Press a paper clip into it. The switch should do a full reset and then reboot. If its just locked up, I would switch off at the power for 15 mins and try let it do an auto restart itself. Do this before you go doing a full button press reset as you may lose any or all updates the switch has had loaded into it.
Sep 02, 2014 | 3Com Computers & Internet
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
I am looking for 3com 4228g default ip address
or 192.168.100.1
Jun 24, 2010 | 3Com 4200 24-Port Ethernet Switch
Benji
sound like its fails the post.manual says should yellow if it fails, green if it passes. maybe hard reset unplug it from power wait a couple minutes plug back in.
May 21, 2017 | 3Com SuperStack 3 4226T (3C17300)...
Feb 25, 2009 | 3Com SuperStack 3 4228G 24-Port Ethernet...
Inherited 2 switches 3com 4228g (3c17403) password problem
Hope that helps
Dec 31, 2008 | 3Com SuperStack 3 4228G (3C17304-US)...
3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Nov 20, 2006 | 3Com SuperStack 3 3300 TM Networking...
Aug 30, 2006 | 3Com 3C16985B SWCH 24-PT 10/100 3300XM...
3Com SuperStack 3 4228G 24-Port Ethernet Switch (0662705446844) Logo
306 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
