Question about Panasonic NN-P295SF Microwave Oven
My NNA 574 has just stopped working, no fan, lights, display. The fuse in the plug is OK. Any thoughts?
  • Panasonic Master
  • 9,047 Answers
OUTDATED POST - PLEASE REMOVE
Posted on Nov 23, 2011
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
I have a Microwave model 721 63252300. It suddenly stopped heating. The other main components are working, fan, light, and turntable. Thoughts?
Hi! from what you have describe, it seem that your magnetron is not working that is why it is not heating. try to look for a busted fuse.
Sep 22, 2009 | Microwave Ovens
No display will not operate no fan no light
Ok, there is an in-line fuse that is located inside the unit on the power supply board. if this fuse is damaged, replace it. If this fuse is ok, replace the entire power supply board.
Jun 01, 2009 | Whirlpool GH4155XP Microwave Oven
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
No lit LED, No panel control. Vent fan, running
We regularly repair these control panels for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 14, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Only the keyboard is working
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, but it's usually a door switch.
Oct 03, 2006 | Danby DMW105 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
