Question about Maytag Neptune MDE6700A Electric Dryer
Have a neptune front load dryer heat does not work either does the lights on the control panel. heat works for a second but panel where time and
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
I have a Maytag Neptune front load model #MDE5500. The light in the tub is on but the control panel display not working. Checked power to to the 220 outlet and all is good. Is this a fuse problem?
door switch most likely, here is a website that will assist you,Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 12, 2011 | Dryers
Control panel got soaked. Panel lights up as normal and does everthing but work - no pump, no water movement. Washer was stopped mid cycle with water in it, naturally.
remove all connectors 1 at a time and make sure theres no corrosion or moisture that can kill system signals,then if theres moisture,carefully dry out boards with heat then again check connections
Mar 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Its a gas neptune with dryer top. It quit heating so I reset it to factory defaults using the technical manual and the heat came back on but only for one cycle, Top heat works fine. Bottom control panel...
heatman101
Jul 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MHW2000 neptune washing machine: There is a burning smell when washing laundry
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####@@@@@
Feb 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
All control panel lights are on at the same time and dryer buttons will not respond and dryer will not start
If the display says '88', then place a heating pad over the display. After a few minutes, the code will clear and the dryer will work. Sounds crazy, but it works for me every time.
Aug 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesn't start every time
bad user interface or control board, I would first check connection between the two
Nov 18, 2008 | Dryers
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
