Question about Frigidaire (PL36DD50EC) Kitchen Hood
My frigidaire PL36DD50EC downdraft vent pops up and then immediately down. It is activated by a button on the top of the unit. Can I fix this myself?
5 Suggested Answers
SOURCE: 30 INCH TELESCOPING DOWNDRAFT VENTILATION UNIT
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Posted on May 13, 2009
SOURCE: dacor downdraft vent
dacor down draft ventilation won't turn on
Posted on Dec 27, 2007
  • 51 Answers
SOURCE: Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Posted on Jul 15, 2009
  • 70 Answers
SOURCE: Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Posted on Aug 21, 2009
Can I install a downdraft vent for my range?
I think you will find it to small to fit behind the range top
May 26, 2014 | Kitchen Ranges
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Pivot arm in telescoping downdraft system sticks when closing
Having the same problem. Unit worked well for 1 1/2 years and then suddenly it dropped after I was thru using it and pushed the arrow for it to go down after it dropped the power wouldn't turn off - had to unplug it.. Repairman came out , took it out, lubricated it , re-installed and next time it went up fine, vented fine but when it went down it dropped again and power wouldn't turn off again. I am hesitant to call him out again unless I can figure out what else might fix the problem. I have noticed that the top piece now seems to be bowed a bit. I guess I can have him take out the cooktop but think there must be enough room for it if it worked fine for the 1 1/2 years. It is a soapstone countertop.
Dec 28, 2008 | GE Profile JVB67 36" Telescopic Downdraft...
Up & down push button not working
Repaired the same problem several months ago. The up/down control has a very small switch located under the button. The switch is part of the selector switch assembly that costs upwards of $100. However, the switch itself is available from Digi Key electronics part # P12321-SCT-ND at about $1.00 each, plus shipping. If you can handle the unit disassembly, which is extensive in this repair, and can solder very small switches, this is an inexpensive fix. I suggest you buy some spares. I'm looking for a seal replacement for this unit right now. Good luck.
Dec 02, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Install a Thermador UCV36 cook'n'vent
Hi schmidt_rich,
I'm Harvey the Master Plumber.
Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchen Ranges Logo
70 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
