Question about Konica Minolta Bizhub 362 Copier
Change PC Drum Message on Bizhub362.How do you resset this message?
  • 1,110 Answers
You are going to need to call your service company and have them replace the drum unit for you. Don't listen to anyone that gives you the service mode entry procedure and drum count reset. This WILL screw up the AIDC (Automatic Image Density Control) and the machine will shut down with a COF32 code. There is a very specific procedure which must be followed when replacing/resetting the drum counter on these machines as there are several "counts" that are tied together. Trust me on this as a 27 year Minolta Tech, spend the money and have the drum unit replaced. They are good for 100,000 copies so even tho it may cost some money to do. Divide that cost by 100,000 pages and it gets pretty cheap.
Good Luck and Thank You for using Fixya.
Posted on Sep 09, 2010
I have a message, please change the pc drum. how i can fix it?
This message means the pc drum life is over. You should call service center to replace the drum and reset the message (if you are not a technician).
Oct 05, 2011 | Konica Minolta Bizhub 362 Copier
Getting a message saying change belt unit...what's that? is it easy to change? Replaced Drum Unit 6 months ago and I still get message Drum Unit end soon.
The instructions to reset the drum after changing are packed with the new drum, and the belt unit is the transfer belt that also wears out and needs changing periodically. The instructions are packed with that also and not hard to change.
Dec 15, 2009 | Brother HL-4040CN Laser Printer
MFC-7420 "Change Drum Soon" I have had this message for a while. I purchased a new drum. In the meantime the printer continues to print fine, except we have paper feed problems. Is the drum related to...
the only time i've seen the drum affect paper feeding is if paper jams in the drum unit. i would use your current drum until print quality decreases to an unacceptable level. it will not shut down, and you will not see a "change drum message." if your paper feed problem is centered around the cassette/paper pickup area, you can try cleaning your rollers with water and a soft rag, and also make sure your rear paper stopper in cassette isn't pressing too tightly against the rear of paper stack. best to leave 1/8" gap, otherwise paper will not lift properly to the rollers.
hth,
razors
Apr 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
1. Open the front cover.
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Konica Minolta Bizhub 362 Copier Logo
807 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
