Question about Whirlpool Duet GHW9150P Front Load Washer
MY whirlpool duet operates properly, but between uses, an amount of water collects in the drum. After 48 to 72 hours this amount can amount to several liters and I have to run the drain cycle to remove it. Otherwise everything works fine. No warning or error lights. Any suggestions?
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance... or there is sediment in the vlve preventing it from fully closing.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
The washer fills slowly with water when not in use. It drains without any problem when drain/spin cycle is used.
Most likely the water inlet valves on your washing machine have failed. You may have noticed larger amounts of water in the clothes drum when the washing machine hasn't been used for a few days, this is because the valves may still be open allowing water to drip into the clothes drum.
Here is a link to the part that you need to buy: http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Washer-water-inlet-valve--universal-item-number-AP3098982.aspx.
And a link to a video showing you how to replace the part: http://www.ultimatehandyman.org/video/appliance_repair/water-inlet-valve.php
Hope this helps!
Feb 28, 2011 | Whirlpool GHW9400 Duet Washer
Finding water in the washer after it sits idle for a few hours. Wife tells me that she completes a wash cycle as normal, moves the clothes to the dry emptying the washer. Then later in the day she returns...
yes its a leaky solenoid water inlet valve,shut off each water fill valve after using the machine and check the drum later to see if its still empty,then do the other4 valve and when you find water then thats the leaky valve,don't try to clean it,just replace the entire valve
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet Whirlpool Front-Loading Washer and the last couple of days I've noticed there has been water in the drum. I ran it through just the drain/spin cycle it appears to remove the water only to...
Sounds like you have a seal issue. Try and shut the water from the back connection off after you do a load. I believe that it sounds like you have a leak from the gasket and it is letting water in when you don't want it there. If the water isnt there then we have narrowed the issue. Please let me know what happens. Hope it helps!
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a wet\moldy odor coming from our Whirlpool Duet Front Load Washer, Model WFW9400S. I opened the washer cabinet up and don't see anything like pooling water or a dead animal. I did notice the hose...
with all the environmental changes made to laundry detergents, consumers should use only 1/2 the amount of detergent they previously used. The detergent build up causes a moldy odor in the washer.
Sep 16, 2010 | Whirlpool Washing Machines
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
