Question about Cameras
The lens couldnt close. it keep saing 'the lens cover is not fully open turn off the camcorder and then on again' but nothing happen
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
May 22, 2007 | Sony Handycam HDR-HC1E HDV Digital...
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Lens keep extended in an out
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Oct 30, 2006 | Sony Handycam DCR-HC90 Mini DV Digital...
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
