WHEN I CUT ON MY LAPTOP..AFTER REINSTALLING WINDOWS XP.. ERROR ERROR FOR.. RELTEK RTL8139X/8130/10X PCI FAST ETHERNET CONTROLLER V2.13 020326 PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING PXE RIM ERROR POOPING UP THANKS FOR THE HELP
  • 3,940 Answers
The system is trying to boot to the Network adapter. If the system boots into Windows after the error, then all you need to do is change the boot sequence in the BIOS (Resetting defaults will likely fix this)
If system is not booting into windows after the error then you may have a hard drive fault
Posted on Sep 09, 2010
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
No audio, no ethernet
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
May 19, 2011 | Intel 865G Motherboard
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
Driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Oct 06, 2009 | Microsoft Windows XP Professional
Reltek insatallation failure - getting access denied error msg
hi realtek high Defifnition not work in your driver....you setup your sound driver --cancel then auto setup ....
Jan 31, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
