Hi our washing machiene wont open atall and there is stuff inside it, Ive tried to open it but no luck!,How do i Open the washing machiene lid off the top to gain acces to our clohes etc thank you
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
Nov 01, 2011 | Estate TAWS850PQ
Cd tray will not open sometimes it would open and other times it wont but now wont open atall the unit does power up
Hi
Open: My Computer, right click the CD/DVD Reader, and click: Eject.
If the CD/DVD didn't get out, so you need to use tall needle; to inject it inthe hole besides the CD/DVD light.
Take care to inject the needle softly.
You can have a closer look at this LINK.
Please, Tell us your results.
Good Luck
May 16, 2011 | Computers & Internet
Nissan sentra 2006 My trunk wont open && I spent 2 1/2 hrs trying to break in from the back seats. trying to reach the seat release but cant. The key or remote wont open it. The car latch wont open...
does the key turn the trunk lock?if not theres one issue right there.the other may be that the valet lever on trunk latch assy. may have inadvertantly been engaged if deck lid was slammed closed.the release solenoid will make noise when activated by fob or lever in car but because of valet being engaged cannot release latch.does key unlock glovebox?if not this may also be a valet key cut.contact nissan dealer to cut regular key.ive seen the slamming the deck lid scenario a million times as the valet lever takes hardly any effort to engage.good luck and let me know how you make out.
Feb 07, 2011 | 2006 Nissan Sentra
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
Trunk wont open
WHEN YOU SAY THAT THE TRUNK WONT OPEN, DO YOU MEAN FROM THE INSIDE OR THE OUT?
WELL IF YOU CANT OPEN THE TRUNK FROM THE INSIDE. TRY OPENING IT FROM THE BACK WITH THE KEY. ONCWE YOU OPEN IT LOOK WHERE THE TRUNK LID MEETS THE CAR WHERE IT MAKES IT S LOCKING CONNECTION. ON THE LEFT SIDE THERE IS A MECHANISM THAT YOU PUSH IN SO YOU CANT OPENING IT. JUST PULL IT AND IT WILL ALLOW YOU TO OPEN THE TRUNK FROM THE INSIDE. GOOD LUCK.
Dec 06, 2010 | 1999 Dodge Stratus
Just got a used front load Wirlpool Washer Model LHW0050PQ with no manual. The door latch doesnt lay flat completely but it seems locked. We washed a couple loads of clothes just fine then we couldnt get...
Hi
The rinse cycle normally takes water in from your cold inlet valve.
To check and see if your cold inlet valve is faulty, turn off your hot water supply. Put the machine on a cold wash cycle and see how fills up. You can open the soap tray slightly while the machine is taking in water and check to see the pressure. If it drips in, then you need to change the inlet valve/solenoide. Repeat the process by putting the cycle on rinse only.
Some machines have a dual-valve or even triple-valve and use a seperate valve for the rinse. in that case you need to change the whole unit.
They are fairly easy to replace. Turn off machine and remove power from its plug. Open the top hatch. Two screws in the back of the top lid, or in some Whirpools a star nut. Pull lid back and up to remove.
See where the cold water hose screws on to the valve unit. take note of the wiring and hoses which come off it to the soap dispenser. You may want to take a picture so that you remember how to put the wiring back.
Remove the valve, most valves are screwed on to the back panel, but some whirlpools are clipped in. If it is a clip type, push the plastic stop in and twist to release it.
It is best if you get the replacement part before hand, so that you can replicate it straight away.
Good luck.
Ash
Oct 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
My washing machine model 110.24642300 was washing last night and just stopped after filling half way. what do I need to do
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Good luck...
Mar 28, 2009 | Kenmore Washing Machines
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Jan 01, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
