Question about HP LaserJet 2100 Printer
Rollers seem to slip when feeding paper so the paper never comes gets printed.
  • HP Master
  • 1,684 Answers
The roller kit you need is RK-2100. You can do a Google search for this item. The kit contains the pickup rollers and the separation pads for both trays and also comes with the transfer roller. You can install them yourself in about 10 minutes. The roller kit is also available here. http://www.ccl-la.com/catalog/product_info.php?products_id=147
BuddyMc
Posted on Feb 25, 2011
Paper is slipping and not feeding through properly in the printing process. It seems like the rollers need some adjusting.
Could be that the rollers are dirty, or that the printer thinks you have thinker paper than you do. To clean the rollers, open the printer, use a liberal amount of canned air, then take a Qtip with rubbing alcohol and brush the rollers, careful to not leave any cotton from the Qtip inside the printer.
Jul 28, 2011 | HP Office Equipment & Supplies
Paper feed not straight straight therefore printing an angle
it is problem transfer roller clean it then solve your problem
Nov 21, 2009 | Samsung CLP 300 Laser Printer
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Oct 08, 2009 | Samsung ML1740 Laser Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
When printing Glossy paper 260gsm, on my HP 4280, the paper appears to be slipping in the feed roller and the image prints too far down the page. Any ideas ??
Take the back cover off, and you will see the feed rollers in there. Use a soft cloth and some all purpose cleaner and gently clean the rollers, not too much liquid on them, lat dry and clean again for couple or three times. You feed rollers have become soiled and are slipping on your paper. I have three hp printers and this must be done every couple months or so. I think I found these instructions on hp.com if I remember right.
Aug 16, 2008 | HP Office Equipment & Supplies
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Feed Problem for 8.5x11 Photo Paper Pro
Please check out the roller and paper setup on the tray, Clean it thoroughly.
Also make the Printer to put it on a Horizontal table if any inclination there.
Regards
Ellin
Apr 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
HP LaserJet 2100 Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
