Question about Microwave Ovens
How do i get fridge to get cold? what way do i turn the knob?
  • 909 Answers
Clockwise is cold Anticlockwise is less cold. If you feel that you need to alter the settings from a prior well running unit, then you will possibly have a problem. If the fridge is to cold the thermostat is faulty.
Posted on Sep 09, 2010
  • Microwave Ovens Master
  • 43,501 Answers
Listen for the compressor to turn on and then turn the knob that way to make it colder...
heatman101
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
Fridge is cold and freezer works but condensation dripping into main part of fridge - everything is getting mouldy - help?!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Microwave Ovens
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ¼-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    heatman101
    Aug 15, 2011 | Microwave Ovens
    Fridge section of fridge freezer not cold despite turning thermostat to max. Freezer section appears to be working fine.
    Make sure that if it has a "colder" knob in the freezer section that it is not set all the
    way over to coldest. This blocks all cold air entering the lower compartment when
    set this way. It actually has been eliminated on some models.
    Also you may have ice buildup in the stack assembly that feeds
    the lower compartment or even a frozen upper compartment behind the back
    panel of the freezer limiting air flow to the lower compartment. Make sure to unplug unit if service is necessary in these areas. I hope this is helpful.
    May 02, 2011 | Microwave Ovens
    I hope someone can help me. I have a Whirlpool Fridge Model Number WRN52HWG6 and we bought it from Fridge and Freezer City O'Connor Perth about 6 months ago and I don't have the owners manual for it...
    If you turn the dial clockwise this will make it colder anticlock less cooler...Start by switching off for a few Hours leave door open to allow defrost...Turn the stat fully anticlockwise to almost off then put it to say 2 o clock position assumming that it will go from 12 to 10,this should allow food to remain cold without freezing.you are looking for about 3/8 Degrees c.....Buy a cheap thermometer this will help to keep you on the right track..Good luck
    Mar 07, 2011 | Whirlpool Microwave Ovens
    Danby mini fridge model dcr054w has stopped working the thing in the back is extremly hot and the fridge no longer gets cold, i turn the knob and i hear a click but the fridge doesnt actually turn on. the...
    This is a problem with the 'Motor Run Capacitor'
    What you suggest is exactly what happens when this part fails.
    Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
    Fit it any way round - it doesnt matter.
    plug back in and should work 100%
    Cost about - $5
    Dec 27, 2010 | Microwave Ovens
    I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
    I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
    I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
    Engineer told me not to waste money calling them out again, and to buy another one...
    Oct 17, 2010 | Microwave Ovens
    I was moving from one house to another and later when i pluged my fridge it was lighting but not geting cold, two days later the light inside went off and still not getting cold.
    If the compressor is hot then you have a compressor fault. If the compressor is cold, then the thermostst is faulty. Im taking it the fridge is a mechanical control.
    Aug 05, 2010 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
