Question about Music
I have a marshall vs100 combo, the problem is sometimes it will work great for weeks on end, and then it decides is wont anymore I get a loud sort of rumbling noise, volume reduction and finally no sound at all, but all the lights are on, any ideas, i have spent 200 pounds over the years and no music repair shops seem to do the job, this is the last stop from the bin.
  • Music Master
  • 5,603 Answers
Intermittent problems like this are hard for the shops to find... the thing will sit for weeks and work while on the bench.
This does have a tube in it, and I am sure that has been replaced, but that is the first thing to replace as the heater in them can break mechanically and come on and off causing intermittent operation.
The next thing is a visual inspection. It takes a trained eye to spot things like cracked circuit boards, broken leads into vilume control pots, and bad solder joints.
You have spent too much so far so this is what I recommend for you to try... It is DIY. Remove the amplifier and take a small soldering iron and some electronic solder (rosin core) and resolder EVERY connection on the board. Trying to have you check the joints is hard to describe other than looking for a tiny grey line on the meniscus of the solder fillets.
Next, get a very bright small LED flashlight and light the backside of the board looking for cracks. Look especially near mounting points of the board AND heavy components like electrolytic canned capacitors.
Look for resitors or components that might be cracked.
Look for areas where the board seems to have heat discoloration marks.
Look for connector problems. The input jacks and the soldering around them are often a problem. Jacks that have switches that allow preamp and access to the power amp OFTEN have poor contacts on the switches that oxidize or get loose.
Remember the vacum tube portion of this runs at high voltage so unplug the unit for a bit before working on it.
lastly, with the unit operating, take an insulated stick and do some poking of components and putting pressure on the circuit board. This looks for marginal component connections and cracks in the circuit traces... one listens for the least scratchy noise in the sound... you dont need audio going through for this test.
Posted on Sep 10, 2010
  • Michial Gueffroy Dec 19, 2010
    A good way to discharge the capacitors at least partially is to unplug the amp while hooked up to the speaker with all the controls turned down. Here is a link to a very good way to do it with a resistor and how to determine the value of the resistorhttp://www.ehow.com/how_6031382_discharg... Do not just use a piece of insulated wire as you will damage the capacitor. Great advice here alsohttp://www.drifteramps.com/safety.html In no way take this to be a criticism of fredy2 s advice which is very good. Just take it for what it is, some extra advice.
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
Could I gut this Amp and MAke it Tube?
Maybe. The cost involved wouldn't reward you enough. Here are some links for you:http://www.drtube.com/marshall.htm and http://duncanamps.com/index.htm and http://www.ampix.org/ If you have all the tools, parts, schematics and above all experience. You may end up with something you like. Personally I would look for a vintage Marshall that needs a rebuild and start there. You will end up with a great amp and the experience you need to mod the MG100DFX if you really want to do it. Hope this helps.
Oct 21, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I got he Marshall MG100FX amp with 2x 12inch speakers. The potmeter of the master volume doesn't work anymore. Do you know the specifications of this potmeter? Armin, delta.design@usa.net
That should be a 320K pot. <br /> <br /> Here's a link to the schematic. <br /> <a href="http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf">http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf</a> <br />
Aug 26, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
When I turn the amp on it makes a loud squealing noise. If I turn it on and off again (several times) the amp will work normal. It doesn't do this all the time; but it is beginning to happen often. When it...
Have a look at this link:http://www.geofex.com/ampdbug/squeal.htm then Back to the Home Page. You may have a bad solder joint some place on the circuit board also. Unless you have experience with electronic repairs you are best served by consulting an accredited Marshall dealer and repair person as there are voltages present that can kill or injure you.
Aug 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi, I have a marshall VS65R I bought in 96. It sat in storage for close to 8 years. I plugged it in and it sounded great....a week later at band rehearsal I played two songs and the sound went out...I...
Some of these have electrolytic caps in the power supply that are nearing end-of-life. I would take unit in for servicing if you are not electronically adept.
First thing though, check for a bad input jack as these often go bad. A wiggle test of the plug should make that possibility reveal itself.
Jun 15, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a marshall avt 100 which was working fine until i plugged new guitar in strummed one chord and the speaker went **** up, so i plugged into another cab and played a while then a week later plugged in...
This is a problem I would recommend for a qualified Marshall amp service person to look at. Worst case scenario is that somehow the speaker out put transformer or the power transformer burned out. They aside from output tubes are the most expensive parts to replace. Add shop labor on top. Ask for an estimate first. Consider how much a new amp will cost and then decide. I would personally go for the repair myself.
Nov 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg50dfx was working great
please check the speaker leads in the back near the edge of the driver (the heavy metal part I think theres 2 in that cabinet )
May 17, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
429 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
