Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Manual for Model #919176851 - CRAFTSMAN Craftsman air compressor
  • 1388 Answers
SOURCE: converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Posted on Nov 27, 2008
hdpanama
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
  • 98 Answers
SOURCE: where do i find the Owners Manual or Service
Its best to use a 30wt non detergant
Posted on Jul 21, 2009
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
Need manual for air compressor mod # 919.165200
I haven't been able to track down the full owners manual, however here is a parts breakdown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919.165200/0247/0703000?pathTaken=
If that link doesn't work go to www.searspartsdirect.com and search for your model number.
Hope that helps,
under_psi
Aug 29, 2010 | Craftsman Air Tools & Compressors
Instructins needed on piston ring replacement on air compressor
GO TO SEARSPARTSDIRECT ENTER THE MODEL NUMBER AND IT WILL SHOW IT ALL TO YA LET ME KNOW IF THIS HELPS YOU
Nov 19, 2009 | Craftsman Air Tools & Compressors
I am looking for a manual for my 33 gallon craftsman air compressor
Hello, Follow this link, and put the model , and number of your compressor in the window. It will provide the manual and exploded diagrams you need.
http://www.managemyhome.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=113226640+CRAFTSMAN
Best regards, --W/D-- Please feel free to rate this solution......thanx!
Aug 01, 2009 | Craftsman Air Tools & Compressors
Need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
49 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
