Question about Roper RAS8445KQ Top Load Washer
It does everything but it will not drain. - Roper RAS8445KQ Top Load Washer
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 09, 2010
How can I find out what's draining my truck battery within 1 or 2 days after charging it? I've unplugged everything I could, but still experience battery drainage.
You have not unplugged everything - otherwise you would have found cause of drain. Hook up ammeter to battery and turn ignition off. Wait about a half hour - take reading on meter then and one by one disconnect and reconnect individual fuses until you find the circuit that has the item drawing the juice that is draining your battery.
Dec 30, 2016 | Cars & Trucks
Battery will not hold charge, something is draining, not a battery problem
Try disconnecting the battery (engine NOT running). Turn everything off. Touch the battery cable to the battery post - if it sparks a tiny bit, you can easily test. If not, use a multimeter (voltage setting) or test light between teh battery post and the cable to verify a drain. If you find NO drain that way, then nothing's draining your battery - you have a battery or alternator problem.
If you DO find a drain that way, then you have to disconnect everything electrical - one thing at a time - until the drain goes away. When it goes away, whatever you just disconnected is the culprit.
Aug 10, 2014 | John Deere Garden
Battery draining overnight,changed to new battery now working
make sure you turn everything off and left everything closed when you shut it off.
May 05, 2014 | 1990 Ford F150
Capri washer
Commonly the drain pump is run by a belt drive, which has possibly broken. You should be able to take the back panel off the washer by undoing several screws, and then look to see if anything is obviously broken.
Aug 24, 2013 | Washing Machines
Ours is dripping water constantly even on only air
The drain is plugged and has everything soaked.... unpluig the drain and give everything time to dry out....
heatman101
Aug 27, 2010 | Heating & Cooling
Does everything but drain
Look for a blockage or a kink in the drain hose.
Some washers will also have a valve and pump on the drain line independent of the main drive. Due to high vibration of the washer, it is not uncommon for wires to come off here.
Checking the drain hose for kinds is easy, just have to look at it and see if there are any sharp bends and such. To do the rest, you are going to have to drain it using expedient methods. Try taping a garden hose to the end of the drain hose, roll the garden hose outside. Lower the drain hose to the floor. If the washer starts to drain with a pretty good flow (washer should be turned off at this point), then you likely don't have a valve on the drain, but the pump isn't working for whatever reason. Let the washer drain as much as it will, remove clothing, and turn the washer over onto its front side.
Remove the bottom cover (if present), and follow the drain line back to the pump assembly. If you have a pump near the drain connection, check its wiring (unplug first) to make sure everything is tight. If the drain line goes to a pump that is driven off the main motor, then the impeller is damaged or coupler is broken.
Most washers will drive the water pump off the same motor that turns everything else. To avoid draining during wash cycle, the main motor will turn in reverse to engage the water pump. If the coupler is damaged, it is able to still run through cycles normally, but can't turn the water pump. The opposite is also true, if it is able to drain, but can't spin or agitate.
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
92 SUNBIRD can't find drain.
hey
u need to check your battery power
turn off everything (car not running) and install an ammeter (use a multimeter which will give you range select capability) in series with a battery lead and then make sure everything is turned off again.. Read the meter. If there is a current drain, the meter will show it. Then you can start removing fuses one at a time to determine what circuit is causing the current drain. Inserting a meter will also resolve the question of whether it is a real drain or some anomaly in the battery.good luck.
Jul 10, 2008 | 1992 Pontiac Sunbird
Drain pump
My husband did remove ours,and we too have a frigidaire 18" built in dishwasher. But ours won't drain, he says it might
be the pump, but he is hoping not.. everything works except when its draining. water just sits there in the bottom.. He took it apart and cleaned everything, but still the same issue.. Any suggestions for me will help also.. TY< PAMMIE
Dec 17, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Roper RAS8445KQ Top Load Washer Logo
41 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
