Question about Samsung Refrigerators
At the frost free refrigirator, the frost is collected at the freezer, what is the pblm? the fridge is under warranty period
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Indesit frost free fridge freezer, less than a week old. The back inside of the fridge has frost on it. I thought it was meant to be frost free. What is wrong please?
I suggest that you contact the people you bought it from and ask these questions. They should be able to answer you as well if there is something wrong they will repair it as its under warranty
Jan 09, 2017 | Frost Refrigerators
Water leaking with icing formation below veg tray. can see flow of water from middle section of the refrigerator,water flowing out of the refrigirator.Model no-RT60KZRIH1
Frost free fridges will periodically allow frost build up to melt and run down the back of the fridge to a small hole which leads the water out and on to the compressor behind the fridge. The water is then evaporated by the heat of the compressor. The hole can get blocked and this leads to the water overflowing and running down to the bottom of the fridge. Clean out the drainage hole regularly.
Jan 30, 2015 | Refrigerators
The top freezer is frosting up. While looking inside the main fridge, in the back there are two square openings. One is dripping water, the other frosted up. In the back of the freezer there appears to be...
drain tube froze up also not allowing water to drain into the bottom drip tube but ur problem is that the fridge didnt automatically defrost so what i would do is call the place where u purchased it and get them to check it out cause it should still b under warranty
Jan 24, 2011 | Whirlpool ET1MHKXM Top Freezer...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
I have FRT18B5AW7, the freezer workes fine but is frosting. The refrigirator is getting warm and all food is getting spoiled. This might some defrost problem. What is exact problem. where defrost timer,...
Is this fridge new?
Does it matter how cold you crank the dial on the fridge -- does it just stay the same temp?
If so, i had this problem with my new fridge.
The manufacturer did not connect the fan before shipping it out. Therefore, the cold air collected in the freezer (alcohol would freeze to sluch) but the fridge stayed the same temp (all the food would go bad).
Since it was still under warranty they fixed it.
Repair man came out, took the freezer apart from the inside and rehooked up the fan. Has worked great ever since.
If this isn't a new fridge than my guess is that the fan has stopped working and might need to be replaced.
Hope this helps.
Good Luck.
Apr 21, 2008 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
