Question about Carrier 38CKC036 Air Conditioner
The compressor is not coming on - Carrier 38CKC036 Air Conditioner
  • 674 Answers
Is the fan in the outdoor unit coming on? If it is, that narrows the problem to just the compressor or capacitor. If neither is running, check the disconnect or circuit breaker or fuses that are located close to the outside unit. If the unit has power, remove the cover where the power goes into the outside unit, set the thermostat to make the unit come on and see if the contactor is pulled in. If it is, use a meter to check for power on the load side of the contactor. If the fan is running, check the capacitor for the compressor. Most units use one that works both the fan and the compressor. If the capacitor looks swollen then it is bad, otherwise use a multimeter with the capacitor check function to test it. If the capacitor is good, check the compressor motor windings with the multimeter on the resistance function. Let me know what you find and I can give you more advice if this doesn't get you going.
Posted on Sep 09, 2010
Air ride compressor not coming on 1988 lincoln mark vii
It could be your compressor. You can check this by popping it out and putting a 12 volt source on it.
Aug 30, 2014 | Cars & Trucks
I have a 05 Navigator the compressor was not coming on at all. I changed the compressor and it still won't come on.
Check for battery voltage at compressor clutch. Check ECM
(computer) for A/C command. Problem could be in control panel.
Make sure A/C button is on (if equipped)
Sep 27, 2012 | 2003 Lincoln Navigator
My compressor don't come on so obviously nothing
the ptc overload/relay on the side of the compressor is most likely your problem,unplug this part off the compressor and get an exact replacement
Jun 03, 2012 | Maytag Refrigerators
Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
Jul 01, 2011 | 2003 Honda Civic
My friedrich unit compressor wont come on
This could be a bad capacitor or your compressor may have gone bad. Another possibility is an overload that is tripped and has to be reset manually. Hope this helps.
Apr 29, 2010 | Heating & Cooling
Compressor comes on but does not cool below 54
Good day,
The compressor is not starting. Either the compressor has failed, or the starting devices mounted on the side of the compressor are bad.
The parts mounted to the side of the compressor, are the overlaod protector, the starting relay, and on some models a start/run capacitor.
These items can be removed from the compressor, and taken to an appliance parts house for testing. You do not have to go to Sears. If the parts check O.K., then the compressor (a major cost item has failed).
P.S. If this machine is under 5 years of age. leave it alone. Call Sears for service. The compressor is under warranty for 5 years.
Jan 01, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac blowing ht air, compressor not coming on
Check the fuses/relay for the compressor. If good, bypass the pressure switch. If the compressor comes on, there is too little internal pressure. Have the system evacuated and recharged. If the compressor does not come on, it could be bad.
May 12, 2009 | 1999 Dodge Grand Caravan
Carrier 38CKC036 Air Conditioner Logo
196 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
