Question about Crafts & Hobbies
Which would be the best to glue ribbon to the fabric strips on window blinds? Hot or the not so hot, so it doesn't burn my fingers. It is brogan ribbon. I think that's how you say it? I'm wanting to add some color to the strips on the blinds. I wan't sure how over time if the sun would weaken the glue and if one would be better over the other. Thanks, Marcia Montgomery
    Champion:
    New Friend:
  • 217 Answers
For something like ribbon a 'not so hot' glue stick should work fine, unless it is in a place where it may get tugged at. hot glue guns usually have stronger adhesive ability, but for you it sounds like it shouldn't matter either way
Posted on Feb 26, 2013
5 Suggested Answers
  • 2712 Answers
SOURCE: Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Posted on Aug 27, 2008
SOURCE: Glue gun support
Try using denatured alcohol from your local hdwe store along with a rag, comb, and even a toothpick . A test area would be my first idea; color fastness and while there is not much odor it may affect some people with allergies and respiratory problems. It will take some time but be careful not to saturate the carpet itself just the immediate area; the alcohol may breakdown adhesives bonding the carpet fibers to the backing or seaming tape on the underside.
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Posted on May 21, 2009
c1apton15
  • 3400 Answers
SOURCE: I need some glue sticks
Check with NorthernTool.com (these guys have everything)
Posted on Mar 10, 2011
What disolves a glue strip for wood transoms?
There is a great product out there called "Goof Off." Be sure to do a test in an area that wont be noticed to make sure it's safe on the surface you're working with.
When you are done be sure to use a damp cloth to remove the fluid and wipe dry immediately.
Depending upon the surface you could also try a piece of cotton fabric and a hot iron. IF the glue is on a smooth surface it should transfer to the cloth. Be careful and don't heat the surface too much.
May 19, 2017 | Crafts & Hobbies
How to change headliner?
You have to remove all the lights and columns that hold it up. Dome light, window moldings. clothing hooks, visers....etc. It will be glued on but if you are gentle then you can get it to peel off. usually not much glue. Just there to help. Once you free it you will have to recline the seats to manipulate it out. Once it is out you have to be careful removing the old fabric so you do as little damage as possible. You are going to break some of the edges but you can hot glue those back on. Stretch on the new fabric and replace. The best to use for adhering the new fabric is a couple of cans of spray on glue.
Mar 09, 2016 | 2000 Isuzu Rodeo
Boston acoustics repair
How did debris get into your speaker?
You might try taking the woofer out by unscrewing all the screws that are holding it in from the front.
As for the grill repair? Are you handy with a hot glue gun and stapler?
Try stretching the fabric over the speaker frame and securing it with hot glue and/or staples. If you use a stapler, get one that fires flat staples not the rounded ones.
If the fabric is torn, find speaker fabric that is "acoustically transparent" commonly available from many sources in many fashionable colors.
you will have to remove the existing speaker fabric without damaging the frame. Scrape off any adhesive residue and remove any and all staples install your fabric by stretching and gluing/stapling the new fabric over the frame.
good luck.
May 26, 2014 | Audio Players & Recorders
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
Display problem
Hi, I had a similar problem and fixed it. Open the calculator and you will see that the ribbon connecting the LCD to the PCB has white and black stripes. The black stripes are the actual conductors. The white pieces are isolation between the conductors and serve the purpose of glueing the ribbon to the PCB.
Take a small flate screwdriver, its thickness has to be that of the white stripes. Heat up the end of the screwdriver with a hot air gun/lighter/hair blowdryer or whatever. Dont make it too hot. It should only be hot enough to melt the glue holding the ribbon to the PCB. Press the screwdriver on a white stripe and move the screwdriver up and down the white line which is on the PCB. Do this for each white stripe individually. Reheat the screwdirver if necessary, since there are a lot of tracks/stripes to cover.
It may be useful to use two screwdrivers: one to heat the glue of a white section and a second to cool/set the glue so that the ribbon is held in place, instead of coming loose because the glue is too hot. I did it only with one mildly hot screwdriver. It shouldn't be so hot that it actually burns you. You can test the temperature by pressing it against a hot melt glue stick (those used in a glue gun), if it melts the glue (but not too quick) it is hot enough.
It is unlikely that the ribbon came loose from the LCD, but if the previous didn't work you can try doing it on the LCD aswell.
Jun 17, 2010 | Sharp EL-334AB Calculator
DualMelt stanley glue gun
For polyesters, rayons, nylon - yes use the low heat setting. The high setting is so hot it can actually melt some synthetic materials. The difference in adhesion between the two settings is minimal. Use the low temperature glues sticks if the gun says there is a difference.
You can use it for this purpose, but it may not be a permanent solution depending on how much stress or load the fabric is seeing (being stretched) when using the furniture.
The best upholstery edges are usually stapled - where the edge or hem of the material is left longer than the area being covered. A picture would be helpful if you want to know the right way to make the edge.
Feb 26, 2009 | Crafts & Hobbies
Left shift key wont go back on
Given that replacement keyboards are not all that horrendously expensive you could actually replace the keyboard if it comes to it eventually.
However, what we did in the old days when replacing keys with worn out lettering was hold a soldering iron on the metal finger the keytop attaches to until the metal of the finger is very hot. Hot enough to push the keytop back on. While you push the keytop down onto the metal finger hold and press firmly for about 1 minute and then release. That should meld the two together if its going to happen at all. Leave it untouched for at least 30 minutes to ensure a firm bond.
This doesn't mean this will be an end all solution to your problem.
Because you mention the broken plastic piece, this mean this keytop may come loose or off again at some time in the future.
If you have tried and used super glue already be prepared for a smoke stench that will come off while you hold the soldering iron on the key finger. Burning super glue is how CSI techs reveal finger prints. That doesn't mean its very safe to breath. So, take some ventilation precautions while you do this. Essentially, do not breath the smoke directly, it will rise quicly on its own until its burned off.
Best of luck,
Worldvet
Jan 05, 2009 | Acer Aspire 5315 Notebook
BMW E46 325 CI SPORT
there is an arasol glue for heat applications for the fabric of head liners you can pick this up at local parts stores or the hot glue you can use theres also carpet glue if you know how to iron upside down use the carpet glue and an old iron that your going to want to throw away cause carpet glue is a little messy but it holds tight and liquid nails this you will have to find some way to support the area of the headliners while liquid nails adheres to the head liners
May 17, 2008 | 2001 BMW 325
Crafts & Hobbies Logo
239 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
