Question about Epson Computers & Internet
When I click to print some lines or parts of them are missing on the printed document . All the cartridges are genuine and tabs removed. (I have cleaned etc), does this printer have print heads could this be the problem?
agentsmith
  • 18 Answers
SOURCE: Cleaning the printer head?
print heads are built into the ink cartridges on HP's. I currently have this problem with another hp model. I appears that the firmware is stuck in what is called 'econo mode' and won't come out of it. good luck. sorry not more help.
Posted on Sep 12, 2007
Benimur
  • 6966 Answers
SOURCE: HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Posted on Apr 08, 2008
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
tigertail
  • 163 Answers
SOURCE: When I print or copy there are missing lines of print.
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Epson recommends printing a colorful document at least once a month to prevent nozzles getting clogged, see the Epson online guide:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwxY9S6wZhcOql4VsOeN1ay&tc=5#10
Hope this helps.
Please take a moment to rate this solution, thanks.
Posted on Mar 30, 2009
  • 909 Answers
SOURCE: hp officejet, pro k5400 printer,when printing i
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Posted on Jun 09, 2009
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
I have an HP Deskjet F380 All in one Printer/Scanner/copier which is about 6months old-it has always performed perfectly but at present I`m having trouble printing photos from computer.The quality of print...
hey payne
here is a copy of your problem.
Issue The printer is working, but colors in the printed output are missing, faded, or dull in comparison to the original. Solution Step one: Check the paper Verify that the paper type is appropriate for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface. Step two: Check the print settings
  1. In the software application you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Verify that your printer is selected and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. In the What do you want to do? menu, select a task. The What do you want to do? menu lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • Print quality: If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size: Make sure this matches your paper.
    Additional options: click the Basics tab, then click Advanced Features . The Advanced Features window opens.
    • Ink volume: Adjusts the amount of ink printed on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the faster the printout will dry.
    • Dry time: Provides extra drying time for slow-drying printouts. Drag the slider to the left for less drying time, or to the right for more drying time. The printer will hold onto the printout until the dry time has elapsed.
Step three: Check the ink levels NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox .
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab and then click Service this device .
  2. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low
99ac57c.gif If the steps above have not resolved the issue, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
  1. Load the input tray with unused plain white paper.
  2. Press and hold the Cancel (c00636162.gif ) button and then press the Start Copy Color (c00636190.gif ) button.
  3. Release both buttons. The self-test page prints.
Step five: Note which cartridges printed which areas of the self-test page You must identify which cartridge printed which part of the self-test page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different self-test page patterns. Your self-test page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Step six: Look for defects In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) should contain few or no missing lines. None of the colors should be missing and the colors of the blocks at the bottom of the page should match the labels below each block. Also, there should be no streaks of ink on the report. Missing lines or streaked bars If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly. Figure 4: The magenta pattern shows missing lines and the bar is streaked 7e505a5.gif
Jun 12, 2008 | HP Office Equipment & Supplies
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
When printing, the blue color is missing
Make sure your print cartridges have enough ink in them for printing.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working color cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X1190 All-In-One InkJet Printer
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
To improve print quality
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
Using the operator panel
Load paper in the All-In-One.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
6 Print your document again to verify your print quality has improved.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
8 If print quality has not improved, try cleaning the print cartridge
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Remove the old cartridges
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print
8 If print quality is still unsatisfactory, replace your print cartridges.
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Canon i455 not printing properly
(i posted this for someone before)
When you remove the black cartridge there will be electrical contacts inside the printer that lines up with some contacts on your cartridge, make sure these are clean
Also, according to this printers manual, have you tried a printer head align?
"(1) Open the Printer Properties dialog box. See Opening the Printer Properties dialog box directly from the Start menu
(2) Click the Maintenance tab.
(3) Click Print Head Alignment.
Follow the instructions on the screen."
Oct 31, 2007 | Canon i455 InkJet Photo Printer
Computers & Internet Logo
19 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
