Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
My frig and freezer seem to work but not cooling anything, all my ice in my ice maker melted. there is some cool air in there. all the seals around my frig and freezer look fine. its been not freezing anything for about 20 hours. i left if alone last night and nothing. usually my kids leave it open and when i close back to normal, but not know. what can it be.
  • Maytag Master
  • 909 Answers
Suggest you do a 12 hour defrost then re switch on. most of the time excess ice is the problem.
Posted on Sep 09, 2010
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator is warm. found ice packed in vents on frig side cleaned them out but now we noticed that the vents in the back of freezer are also packed with frozen ice build up. could this be the reason for...
That ice is the reason that the freezer is working but the refrigerator is not cooling. That ice is
blocking the vent that allows cool air to leave the freezer section andfall down into the refrigerator
section.
The fix is free: defrost the frig - pull the plug, and let that icce melt out of there, clean up the
wet mess, and turn the frig back on - problem solved.
Keep the vent area free of ice (and other blockages, like frozen peas covering over the vent), and
you'll keep the problem from recurring.
Aug 08, 2011 | Refrigerators
The ice maker makes ice and fills the ice bin but every few days the ice melts and creates a frozen ice scicle path to the lower tray and all the ice has melted and frozen again below the ice maker.
The problem with the ice melting points toward a cooling problem in the freezer. This could be caused by several different problems. Dirty condenser coils below the refrigerator could be contributing to this problem. I recommend checking and cleaning these coils if necessary.
Check the door seal on your freezer. A leak through the freezer door seal may be allowing warm air to enter the freezer and melt the ice.
Make sure that your temperature control is set properly.
If these tips do not help resolve the problem, it is likely that you have a component failure or a sealed system problem. The thermostat could be bad. You could have a condenser or evaporator fan problem. You could also have a defrost system failure that is causing your cooling problem. A weak compressor would also cause this symptom.
Jan 17, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling down below 60 degrees f.
hi!!! make sure your inside fan is blowing and also go to back of your frig and see if the compressor and condensor fan are working if not then thats your problem..If they are working then you have a seal system problem in your frig..make sure when you look at the compressor you try to hear a cliking sound if you do then change the current relay..Good luck..
Jan 04, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
The freezer is working the frig isn't
YES , you need to replace the thermostat timer,its a device that operates like every 30 min or so applying heat thru a black element to keep the freezer from not building up ice . hope this helps AJ
May 12, 2008 | Amana ABB1927DE Bottom Freezer...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
118 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
