We use a Proxima Ultralighht S520 and we are getting vertical lines that skew/blur the image. It started on the left and eventually encompassed the entire screen. Can it be adjusted?
  • 3,083 Answers
This type of noise bars is usually due to a faulty capacitor in the power supply. The paper or metal electrolytic caps go bad after a period of time, and most techs replace them all at once to restore integrity to the unit, and often it rejuvenizes it to an almost new state of performance.
That's the most likely thing, and should be tried first.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 09, 2010
  • 2,973 Answers
Please go to printer trouble shooting in the Control Panel and calibrate the lines and colors. Once that is done the blurring will be eliminated.
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
My proxima dp6155 projector after any time looks with a vertical purple line in the right side, whats the problem
reset the settings to factory default. there may be a resolution issue. make sure it matches the source. if the line is straight and goes right along the pixel line, you may have an lcd issue. if it's blurred, it could be a bad polarizer.
Dec 16, 2009 | InFocus Office Equipment & Supplies
My Proxima S520 seems to work fine in any
When the lamps are replaced, you need to ensure you have screwed the lamp assembly into the cavity tightly. The lamp assembly presses against a tiny micro switch - if it is slightly loose, then this might trigger a malfunction when the unit is moved.
Other possibility is, perhaps the micro switch is faulty.
Cheers,
"If this has helped you, please rate this solution"
Dec 01, 2009 | InFocus Proxima UltraLight S520 Multimedia...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Canon S520 printer won't print
there is a encoder strip in the printer to which the cartridge head carriage reads .if this encoder strip is dusty or loose the carriage cannot read so it bangs from left to right.and due to this printer cannot get set to its position.and the orange error light blinks.that transperant long strip with blacl vertical lines on it has to be checked.
Jan 29, 2009 | Canon S520 InkJet Photo Printer
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
12 people viewed this question
jasbo
jasbo
