Question about Kyocera Office Equipment & Supplies
Error E-320 Kyocera KM 1620 - Kyocera Office Equipment & Supplies
4 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
leroyal
  • 2120 Answers
SOURCE: Copystar/Kyocera 1620 error code: C-6 000
The fuser needs to be reset.
Posted on Mar 04, 2009
  • 215 Answers
SOURCE: kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
Posted on Mar 30, 2009
How do I fix A-4200 problem on KM - 1620 Kyocera copier
Try the main charge first...if not working Replace the laser unit.
May 28, 2015 | Kyocera Km 1620 Cs 1620 Copiers Copy...
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
CAN KYOCERA COPIER KM - 1620 BE USED AS APRINTER
no sir km 1620 is basic copier machine. for printer series you should go with km 1635/2035/1650/2050 or the newest one taskalfa 1800
Mar 13, 2014 | Kyocera Office Equipment & Supplies
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
HOW TO SOLVE J41 IN KYOCERA KM 1620
This is a jam error code check the exit sensor replace if faulty
Mar 01, 2011 | Kyocera KM-1510 Copier
Kyocera KM-1620 as a printer??
Yes, it can be connected as a printer -- see this page where you can download the print drivers:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=11917&pcat=10564&rcid=10009&rscid=10007#bottom
However, it may need an optional interface attached. Check the back of the machine to see if there is a USB port (the squarish one). If there is nowhere to plug in the USB cable, you may need to buy the printer interface option.
Jul 07, 2010 | Kyocera Copystar CS-1620 Black and White...
48 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
