Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
How come gas comes out of the air filter when I put gas in it?
  • 183 Answers
Within the carburetor on your engine, is a float that is attatched to a needle valve with a rubber seat that the needle presses up against. As fuel goes into the carb, the float is lifted and the needle shuts off the fuel flow against the seat. In your carb, either the float is not floating, or the needle is not sealing against the seat. The solution is to either clean and rebuild the carburetor, or replace the carburetor. I also recommend to replace the air filter since it has been gas fouled.
Posted on Sep 09, 2010
Changed oil and gas filter and spark plug but wont start. wont pick up its gas
put a little gas directly in carburetor and see if it starts with air filter off. if it dose, drain carburetor using screw on bottom of bowel then put more gas in carburetor , and start it and let it run for awhile then put air filter back on. it should work.
May 18, 2015 | Garden
I have brand new Whirlpool gas water heater and forgot to put on air filter. Have tried to light the pilot light and it will not stay lit. Can you tell me if the air filter could cause this
Not unless the system has a fault switch whereby the switch requires a filter to activate the heater. Generally Not.
As a rule, your GAS company will come to your residence FREE of charge to check the heater and start it for you.
Apr 02, 2015 | Whirlpool Water Heaters
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Idles ok revs up and stalls out
Aug 13, 2013 | Poulan Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
In idol, comes extreamly close to dying on me. I have to keep on the gas to keep 'er going. Feels like there isn't enough either fuel or air getting to the engine. I just cleaned the air filter and put...
try changing the spark plugs and wires
oil change
replace the air filter if its the reguler one and not the cleanable ones
put some fuel injector cleaner in the car
these are some options ^-^
i hope this helps
Aug 06, 2010 | 1997 Volkswagen Jetta
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
242 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
