Question about Dell 1815dn All-In-One Laser Printer
My scanner has locked, don't know why. I found the blue toggle, but it will not unlock. Manual gives no other option. What do I do to unlock scanner?
  • elaine569 Sep 09, 2010
    Info on the mechanical switch was very helpful. Thanks for the details the operating manual did not give.
    Brigadier General:
  • 3,917 Answers
Hi
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of the printing output slot.)
This prevents the scan head from damage when the printer is moved. some scanners have a mechanical lock to keep the scan head in place during shipping. Look around near the scanner glass, sides, and possibly even in it for a slide lock or something to that effect.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If nothing works then try the scanner on another computer to verify that it is not just a conflict on that particular computer or the card is faulty.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 09, 2010
How do you unlock channels on scanner
Hi Lori,
Many times, you need to switch to MANUAL mode (out of scan) and step thru each channel. The display will indicate if the particular channel is locked out by symbol or text. Pressing ENTER or LOCKOUT (depending on model scanner) should toggle a locked out channel back into the scan - and a scanned channel into lockout.
Without knowing your scanner model - it's difficult to tell you exactly how to do it. If my suggestions do not work, reply and include the brand and model number so I can get you the exact steps to solve your problem.
May 29, 2013 | Uniden Radio Communications
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
We have 2 WASP WWS500 wireless freedom scanners that we have been working great with desktop computers (we don't use a pairing pass code). We have just bought two tablet's (HP Touchpad) and would...
Go to your blue tooth settings and delete it. After you delete it click on add blue tooth device. There is when it will ask you the 3 option's. The bottom Option is the one you want. (DON"T NEED A CODE OR DIDN"T COME WITH A CODE)
Jul 16, 2011 | Wasp WWS800 Handheld
How do I unlock the scanner on a dell laser MFP 1815 dn printer. I can't fax or copy anything. It says the scanner is locked.
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Aug 27, 2010 | Dell Printers:Dell MFP Laser Printer...
Visioneer 9000 Scanner Unlocked ????
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
May 26, 2008 | Visioneer OneTouch 9000 Flatbed Scanner
Error red light on.
are you having an error on the LCD screen?
Mar 21, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Scanner locked
Mar 19, 2008 | Dell 1815dn All-In-One Laser Printer
Won't delete message in outbox
THANKS!!!! I did not know about the [ _ ] key above the top arrow... wow, it was driving me crazy. I have been able to delete my old messages... I really appreciate the info!
Oct 19, 2007 | Motorola Mobility RAZR V3
Scanner lock is on
Do you not have a manual or 'get you started sheet?' It is the first thing you do when unpacking a scanner is to unlock the shipping lock. In all probability it is under the scanner base so if it is a lifting item[to access the printer] check there,or on the backplate of the scanner where all the sockets are. Failing that get onto the Tech support site at Canon.
May 16, 2007 | Canon MP830 All-In-One Printer
Dell 1815dn All-In-One Laser Printer Logo
749 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
