Question about Cameras
Cannot transfer internal memory onto an SD card
  • kakima Sep 09, 2010
    What make and model? Most cameras will have this feature in either the Setup or the Playback menu. Sorry, but I can't give you any more information without knowing what camera we're discussing.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume my suggestions pointed out the appropriate solution.
Posted on Oct 15, 2010
How do I take the pictures out of the internal memory and put them on an SD card so I can take them OUT of the internal camera memory?
Use the "Copy" command in the Playback menu to copy the pictures from the internal memory to the card. Once the pictures have been safely transferred to your computer, format the internal memory to clear it.
Jun 19, 2012 | Nikon Coolpix S6100 Digital Camera
I cannot transfer picture to memory card how?
Connected the camera with the USB cable at pc, open Explorer pc program to view like a "external device", select your files and copy/paste en each folder.
Other way could be using some external device to your SD Card.
Sep 29, 2011 | HP Photosmart 435 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
Dec 06, 2010 | Pentax Optio A10 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Transfering images to SD Storage card
    I'm not familiar with your camera but most of them have a listing in the menu for "copy" with instructions on how to transfer from the internal memory to the memory card.
    Nov 17, 2009 | Samsung Digimax D53 Digital Camera
    Cameras Logo
    Top Cameras Experts
    Steve
    Are you a Camera Expert? Answer questions, earn points and help others
