Question about NetManage ViewNow InterDrive Client 7.1 (910070001A)
Ihave a new computer wit windows 7 prof 32 bit. Itried to install the ViewNow inter drive client 7.1.1 without success. Even in compatibily mode it will not work. Any soloutions? Thank you in advanced
Is adobe photoshop elements 3 compatible with windows 7
I want to mention that Photoshop Elements 3 is not tested with the Windows 7.
If you have a windows 7 64 bit operating System then it may not even install in it. If you have a 32 bit Operating System then you can try to install it. However it may still not work even on a Windows 7 32 bit Operation System as it was not made and tested for this Operating System.
There is a probability that if you install the Windows XP mode on you Windows 7 operating system then it may work.
Check more about installing Windows XP mode here:
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7 Install and use Windows XP Mode in Windows 7
Regards
Anand
Aug 30, 2014 | Computers & Internet
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
My HP Probook 4520S came with Windows 7 Professional 64-bit. I noticed that toggling the num lock key always displayed its status on the screen. After formatting the drive and installing Windows 7...
Best regards, i can say that it really problem, that problem with 64 bit, driver problems will be all time with printers, scaners, webcams, and other. I think will be better, if you reinstall windows 7 32 bit, for work without probles.
May 30, 2011 | HEWLETT-PACKARD ProBook 4520s Notebook
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Hi sir im jeff and my question is that i cant scan my computer windows 7 prof using windows live essentials.
Hello
I am also using win 7 home premium.With microsoft security essentials.
There could be a few reasons why its not working for you.
1 If you have another anti virus program it must be completely un installed.
2 You downloaded win 7 32 bit, and not win 7 64 bit version.
3 Download corrupt.un install essentials and re download and install.
Hope this helps.
Thank for using Fix ya
Feb 06, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Windows 7 can't find HP7310 all in one printer
Go to this link you will find a solution on how to configure your printer in windows 7.
http://www.fixya.com/support/r5205380-installing_printer_in_windows_7
Jul 17, 2010 | HP Office Equipment & Supplies
Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
Feb 04, 2010 | HP Scanjet 5470c Flatbed Scanner
I just upgrade to Window 7, to my ACER AspireOne Netbook. Successful install with no problems. I have Acer X163W Monitor to use with my Acer Netbook, before install Win 7, I was able to setup the monitor...
As of now, there are no Windows 7 drivers for that monitor.
Here is the Vista driver:
Acer X163W Vista 32-bit Driver
You can try installing this in Windows 7 using compatibility mode and see if it works. Otherwise, just try to contact them directly or try and submit a query about it.
Oct 31, 2009 | Samsung 941BW LCD Monitor
NetManage ViewNow InterDrive Client 7.1 (910070001A) Logo
47 people viewed this question
Top NetManage Computers & Internet Experts
David Payne
David Payne
Are you a NetManage Computer and Internet Expert? Answer questions, earn points and help others
